1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Question about this mailing list
From: Ralph Lange via Tech-talk <[email protected]>
Date: Thu, 29 Nov 2018 09:18:44 +0100
I can report that the Gmail web interface also acts reasonably, i.e. "Reply" goes to author only, "Reply all" goes to author CC tech-talk (like this mail).
Also:
  • The new setup makes "To:" and "From:" addresses the same. Some mail apps may act funny in those cases.
  • Microsoft Outlook is known for having its own interpretation of RFC 822, such as ignoring "Reply-To:" headers and threading by "Subject:" content instead of using "In-Reply-To:" headers.
Cheers,
~Ralph
On Wed, 28 Nov 2018 at 23:20, Mark Rivers via Tech-talk <[email protected]> wrote:
Folks,
Recently Argonne required changing the mail headers for mailing lists like tech-talk and core-talk to improve security.
I am now having a problem when I want to reply to a tech-talk or core-talk message.
Prior to this change when I did “Reply All” it sent a reply to both the original sender and the list.  If I did “Reply” it went only to the sender.
Now when I do either “Reply All” or “Reply” it goes only to the sender, not to the list.  I am seeing this behavior when using Outlook, Outlook Web client, and the Mail application on an iPhone.  In the mail application on the iPhone it does not even list “Reply All” as an option, only “Reply”.  I find this quite inconvenient, because I need to remember to add “tech-talk” even if I do Reply All.
Have others seen this behavior?  Is there some setting in Outlook which can be used to allow “Reply All” to also send to the list?
Andrew Johnson reports that the Thunderbird e-mail client does work correctly, Reply All goes to the list as well.
Re: Question about this mailing list Mark Rivers via Tech-talk
Prev: Re: Question about this mailing list Ivashkevych, Oksana via Tech-talk
Next: Problems with using PI E-712 controller 孙天啸 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: Re: Question about this mailing list Mark Rivers via Tech-talk
ANJ, 29 Nov 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
