Hello everyone.
In epics 3.16 I see a couple of .pc files are generated and installed:
./lib/pkgconfig/epics-base-linux-x86_64.pc
./lib/pkgconfig/epics-base.pc
Nonetheless, when using pkgconfig to build/link against Epics, needed
-lca -ldbCore -lCom are missing from the command line.
Looking at the "Libs:" line at the bottom of epics-base-linux-x86_64.pc,
I see they are actually missing. I added them manually and the build works.
Am I missing something or is it a bug?
Thanks.
Giacomo, Elettra Synchrotron Radiation Facility, Trieste, Italy.
A portion of the .pc file follows:
EPICS_BASE_IOC_LIBS=dbRecStd dbCore ca Com
# Directories
includedir_osi=${prefix}/include
includedir_osd=${prefix}/include/os/Linux
includedir_comp=${prefix}/include/compiler/gcc
includedirs=${includedir_osi} ${includedir_osd} ${includedir_comp}
dbddir=${prefix}/dbd
dbdir=${prefix}/db
# Tool chain
CC=/usr/bin/gcc
CXX=/usr/bin/g++
CPP=/usr/bin/gcc -x c -E
AR=/usr/bin/ar -rc
LD=/usr/bin/ld -r
Version: 3.16.2.0
Description: EPICS Base for linux-x86_64
Cflags: -I${includedir_osi} -I${includedir_osd} -I${includedir_comp}
-D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -D_X86_64_ -DUNIX
-Dlinux -mtune=generic -m64
Libs: -L${libdir} -rdynamic -m64
Libs.private: -lpthread -lreadline -lm -lrt -ldl -lgcc
- Re: lib/pkgconfig/epics-base-linux-x86_64.pc: are -lca -ldbCore -lCom ... missing from Libs ? Michael Davidsaver via Tech-talk
Problems with using PI E-712 controller 孙天啸 via Tech-talk
streamdevice I/O Intr William Kirstaedter via Tech-talk
<2018>
Re: Problems with using PI E-712 controller Mark Rivers via Tech-talk
<2018>
