Yes, I am issuing
caput CRYVISIL:TC09:Toggle 0
when the IOC starts and the device doesnt already send data, I am
able to toggle with
caput CRYVISIL:TC09:Toggle 1
which results in "STM\r" showing up in the asyn TraceMask,
followed by the stream.
When simulating the process "by hand" with telnet, it's no
problem sending STM and ETM.
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 29.11.2018 um 16:10 schrieb Michael
Westfall via Tech-talk:
How are you commanding the bo record?
Are you sure its value is being commanded to zero when you
want to stop reading?
Did you try something like, 'caput xxx:Toggle 0' ?
On Thu, Nov 29, 2018 at 10:21 AM William
Kirstaedter via Tech-talk < [email protected]>
wrote:
Hi Dirk,
thanks for the quick answer.
I have set
field(PRIO, "HIGH")
but this doesnt seem to do anything?
I have asynTraceMask on aswell but I dont see the "ETM"
command ever
pass through...
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Am 29.11.2018 um 13:37 schrieb Dirk Zimoch via Tech-talk:
> Hi William,
> Have you tried to give the output record a high priority?
> Dirk
> On 29.11.2018 13:27, William Kirstaedter via Tech-talk
wrote:
>> I'm sorry to send this again but my first mail got
soft-rejected
>> because I wasnt a subscriber.
>> Faradayweg 4-6
>> 14195 Berlin
>> Tel: 030 8413 5405
>> Am 29.11.2018 um 11:34 schrieb William Kirstaedter:
>>> Hi,
>>> I have a small problem with a fast Device, maybe
somebody already
>>> had this problem and can help out? :)
>>> It runs via I/O Intr.
>>> I am able to start the reporting, but I cant stop
it. It seems that
>>> the stop command doesnt get through....
>>> could it be that somehow the communication is
blocked by the fast
>>> input? how could I fix that?
>>> Its really simple to control:
>>> You send "STM\r", it starts reporting every 18ms
>>> "tmp,<float>,<float>\r"
>>> You send "ETM\r", it stops doing that,
terminating communication
>>> with "txx\r".
>>> all ASCII formatted.
>>> my records:
>>> tc.db file:
>>> record(bo, "$(P):$(R):Toggle"){
>>> field(DESC, "Toggle Reading")
>>> field(DTYP, "stream")
>>> field(OUT, "@tc.proto toggle $(BUS)")
>>> field(ZNAM, "ETM")
>>> field(ONAM, "STM")
>>> field(VAL, "0")
>>> record(ai, "$(P):$(R):Temperature") {
>>> field(DESC, "Temperature")
>>> field (DTYP, "stream")
>>> field (INP, "@tc.proto read_K $(BUS)")
>>> field (SCAN, "I/O Intr")
>>> field(EGU, "K")
>>> record(ai, "$(P):$(R):ThermoVoltage"){
>>> field(DESC, "TC Thermovoltage")
>>> field(INP, "@tc.proto read_nV $(BUS)")
>>> field(SCAN, "I/O Intr")
>>> field(EGU, "nV")
>>> tc.proto file:
>>> Terminator = CR;
>>> ExtraInput = Ignore;
>>> toggle {
>>> out "%{ETM|STM}";
>>> in "txx";
>>> read_K {
>>> in "tmp,%f,%*f";
>>> read_nV {
>>> in "tmp,%*f,%f";
>> Das FHI verarbeitet, speichert und loescht Daten im
Rahmen seiner
>> Geschaeftstaetigkeit gemaess der
Datenschutz-Grundverordnung (DSGVO)
>> [General Data Protection Regulation (GDPR)] der
Europaeischen Union.
Das FHI verarbeitet, speichert und loescht Daten im Rahmen
seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung
(DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen
Union.
Mike Westfall
Control Systems Software Engineer
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
