Hi Dirk,
Since this seems a viable solution - is it worth to be added to the streamDevice docs?
Cheers, ~Ralph
>> I [...] somehow got around it by setting ReadTimeOut and
>> PollPeriod to half of the input rate:
>> rdInputCont{
>> ReadTimeout = 10;
>> PollPeriod = 10;
>> in "%#s";
Interesting. PollPeriod defines how often "I/O intr" records poll for
input if no other records read input. It defaults to ReadTimeout btw.
So if poll period is too long, some input may pile up and only gets
consumed when the next record reads input or flushes input before
writing. The default ReadTimeout and thus PollPeriod is 100 ms. Thus in
your case up to 6 input messages may be pending in this time. More if
processing the messages takes considerable time. That does not look too
much to me. So I still wonder why the input queue never gets empty.
Having a PollPeriod about half the expected input rate is definitely a
good idea, because it reduces latency (at the cost of CPU usage of
course). Otherwise you will see input in bursts.
- Fwd: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
- Re: Fwd: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Re: Fwd: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Re: Question about this mailing list Mark Rivers via Tech-talk
<2018>
Re: Fwd: Re: streamdevice I/O Intr Christoph Schroeder via Tech-talk
<2018>
ANJ, 30 Nov 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
