I added a ton of spaces between ENgain, and ENoffset.
it now throws this:
2018/12/13 12:15:59.388784 _main_ Cannot find a bus named
'CRYVISIL:LEED:ENoffset,CRYVISIL:LEED:ENvalue,CRYVISIL:LEED:ENmonitorU,CRYVISIL:LLEED_01'
for 'CRYVISIL:LEED:getEN'
2018/12/13 12:15:59.388860 _main_ CRYVISIL:LEED:getEN:
Can't attach to bus
-1
2018/12/13 12:15:59.388879 _main_ CRYVISIL:LEED:getEN:
Record initialization failed
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 13.12.2018 um 10:21 schrieb Ralph
Lange:
Can you try adding a lot of spaces to the link
field in your database?
This looks like Base might not be able to handle a case
where the link field is getting longer by macro substitution.
Cheers,
~Ralph
On Thu, 13 Dec 2018 at 09:46, William Kirstaedter
via Tech-talk < [email protected]> wrote:
unlimited cant be the case, unfortunately. I'm running
EPICS7 and facing the following error when starting the
IOC:
2018/12/13 09:42:51.409543
_main_ Missing ')' after substitutions
'readModule(EN,CRYVISIL:LEED:ENgain,CRYVISIL:LEED:ENoffset,CRYVISIL:LEED:ENvalue,LEED_01'
2018/12/13 09:42:51.409621 _main_
CRYVISIL:LEED:getEN: Protocol parse error
2018/12/13 09:42:51.409642 _main_
CRYVISIL:LEED:getEN: Record initialization failed
with these records and streamprotocol:
# Energy record(stringin, "$(P):$(R):getEN") { field(DTYP,"stream") field(INP,"@leed.proto readModule(EN,$(P):$(R):ENgain,$(P):$(R):ENoffset,$(P):$(R):ENvalue,$(P):$(R):ENmonitorU,$(P):$(R):ENmonitorI) $(PORT)") }
record(ai, "$(P):$(R):ENgain") { field(DESC,"Energy Gain") field(EGU,"eV") field(PREC,"2") } record(ai, "$(P):$(R):ENoffset") { field(DESC,"Energy Offset") field(EGU,"eV") field(PREC,"2") } record(ai, "$(P):$(R):ENvalue") { field(DESC,"Energy Value") field(EGU,"eV") field(PREC,"2") } record(ai, "$(P):$(R):ENmonitorU") { field(DESC,"Energy Voltage Monitor") field(EGU,"eV") field(PREC,"2") } record(ai, "$(P):$(R):ENmonitorI") { field(DESC,"Energy Current Monitor") field(PREC,"2") field(EGU,"A") }
------------ OutTerminator = CR; InTerminator = "\r\000\n>";
readModule{ # $1 : Module Name -> REN (read energy) out "R\$1"; # answer: R $1 r NUL n $1 (what out "typed in" plus return) $1|SP|GAIN|SP|OFFSET|SP|VALUE|SP|U-monitor|SP|I-monitor (the actual answer) # >REN # EN +0 +500 +500 +500.85 +1.5653E-06 in "R\$1\r\000\n\$1%(\$2)f%(\$3)f%(\$4)f%(\$5)f%(\$6)f"; }
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Am
12.12.2018 um 17:29 schrieb Johnson, Andrew N.:
On 12/12/18 8:59 AM, William
Kirstaedter via Tech-talk wrote:
Short Question:
Whats the maximum length of a record field? how many
chars?
record(ai,"record_name"){
field(DESC, "I_mean_this")
field(INP, "how_long_can_this_be")
Longer answer:
That depends on the field definition for the record type.
DESC is defined in dbCommon.dbd (a kind of super-class
used by all record types) as:
field(DESC,DBF_STRING) {
prompt("Descriptor")
promptgroup("10 - Common")
size(41)
That means it's a DBF_STRING and the size() entry says it
can hold up to 41 characters, but there must be a
zero-byte terminator so the limit is really 40 (which
matches the Channel Access dbr_string_t typedef).
For something like the ZRST field of the mbbi record which
defines an enumeration string, the size is given as 26
which is the size of the enumeration strings that Channel
Access can send in a struct dbr_gr_enum.
An INP or OUT field is a link and for these the maximum
length depends on the version of EPICS you're running; it
might be 40 for older versions, 80, 256 for some or
unlimited for EPICS-7.
HTH,
- Andrew
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
