I tried installing EPICS and synApps to two different directories, and synApps failed at the same point, even on my linux-x86_64 machine. Since this approach would not work for us for other reasons, I plan to abandon this approach unless someone wants more details.
Thank you,
Iain.
> -----Original Message-----
> From: Jeong Han Lee <[email protected]>
> Sent: Thursday, December 13, 2018 8:31 AM
> To: [email protected]
> Cc: Iain Marcuson <[email protected]>
> Subject: Re: FW: Build failure when compiling synApps from source
> Hi Iain,
> INSTALL_LOCATION in BASE and SYNAPPS should be different. "make
> clean or uninstall" will remove the BASE also. So it is better to use other
> directory.
> I tested two tests on Debian 9 and Raspbian 9 as following environment
> variables:
> * Debian 9
> EPICS_BASE=/opt/epics
> SUPPORT=/home/jhlee/playground/synApps/support
> * Raspbian 9
> SUPPORT=/home/pi/playground/synApps/support
> With the enclosed instruction, I can install all on Debian 9
> (linux_x86_64) and all except DXP and DXPSITORO on Raspbian 9
> (linux-arm) without any issues. You may try to do this first, and switch the
> INSTALL_LOCATION of synApps differently, for example,
> /opt/epics/synApps-6.0.0 .
> I may try it later, since my old Raspberry Pi is not so powerful, it takes a lot
> of time to do this.
> All what I've done is that I configured and installed with the direct compiling
> on each architecture.
> HTH,
> Han
> On 12/12/18 3:43 PM, Jeong Han Lee wrote:
> > Hi Iain,
> > I have one more question :
> > Could you install epics through cross-compiler or on the linux-arm
> > directly?
> > If you do on the linux-arm directly, could you install epics through
> > https://github.com/jeonghanlee/epics_manifest ; ?
> > You can simply follow README to how it works. I don't recommend to
> > use this, but I would like to see whether your OS has issues or not.
> > It doesn't contain the synApps, but some of them with proper orders.
> > Maybe this is not the proper way, meanwhile I am setup with synApp on
> > my old RPi.
> > Best,
> > Han
> > On 12/12/18 3:37 PM, Jeong Han Lee wrote:
> >> Hi Iain,
> >> Which EPICS BASE do you use?
> >> Han
> >> On 12/12/18 3:09 PM, Iain Marcuson via Tech-talk wrote:
> >>> asyn/config/RELEASE does point to $(SUPPORT)/seq-2-2-5.
> >>> *From:* Mark Rivers <[email protected]>
> >>> *Sent:* Tuesday, December 11, 2018 3:24 PM
> >>> *To:* Iain Marcuson <[email protected]>;
> Johnson,
> >>> Andrew N. <[email protected]>
> >>> *Subject:* RE: FW: Build failure when compiling synApps from source
> >>> Does asyn/config/RELEASE have an entry that correctly points to
> >>> $(SUPPORT)/seq-2-2-5? If so, it should find the rule to build .st
> >>> files.
> >>> *From:* [email protected]
> >>> <mailto:[email protected]> <tech-talk-
> [email protected]
> >>> <mailto:[email protected]>> *On Behalf Of *Iain
> Marcuson
> >>> via Tech-talk
> >>> *Sent:* Tuesday, December 11, 2018 2:04 PM
> >>> *To:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
> >>> *Cc:* [email protected] <mailto:[email protected]>
> >>> The synApps RELEASE files point to $(SUPPORT)/seq-2-2-5. That said,
> >>> how would I install EPICS and synApps in a distinct directory if I
> >>> need to include the source?
> >>> Iain.
> >>> *From:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
> >>> *Sent:* Tuesday, December 11, 2018 2:57 PM
> >>> <mailto:[email protected]>>; tech-
> [email protected]
> >>> *Subject:* Re: FW: Build failure when compiling synApps from source
> >>> Hi Iain,
> >>> On 12/11/18 1:20 PM, Iain Marcuson via Tech-talk wrote:
> >>> I was able to build the standalone sequencer fine. Yokogawa
> >>> appears to build, but asyn fails with
> >>> make[4]: *** No rule to make target `ipSNCServer.o', needed by
> >>> `libtestIPServerSupport.a'. Stop.
> >>> The sequencer provides its own set of build rules which the EPICS
> >>> build system will pull in automatically from the sncseq module when
> >>> you list it in your application's configure/RELEASE file. This isn't
> >>> happening for you, and I suspect you're trying to use a modified
> >>> build system since you also wrote this earlier:
> >>> -snc binary in /opt/epics/bin/linux-arm
> >>> That isn't how the sequencer normally comes, GNUmake needs to see
> the
> >>> contents of the sncseq/configure/RULES_BUILD file for any application
> >>> that needs to compiler sequence programs.
> >>> - Andrew
> >>> Arguing for surveillance because you have nothing to hide is no
> >>> different than making the claim, "I don't care about freedom of
> >>> speech because I have nothing to say." -- Edward Snowdon
- Re: FW: Build failure when compiling synApps from source Jemian, Pete R. via Tech-talk
- Re: FW: Build failure when compiling synApps from source Jeong Han Lee via Tech-talk
- Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Fw: Build failure when compiling synApps from source Mark Rivers via Tech-talk
- FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Re: FW: Build failure when compiling synApps from source Johnson, Andrew N. via Tech-talk
- RE: FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Archiver Appliance: merging STS, MTS and LTS pb data from a backup to a live system Rory Clarke - UKRI STFC via Tech-talk
Re: Merging store STS/MTS/LTS data from a live system with a backup Shankar, Murali via Tech-talk
<2018>
<2018>
