1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: Stream fails on windows-x64 against base-7.0.2
To: "'Gofron, Kazimierz'" <[email protected]>
Date: Thu, 20 Dec 2018 20:18:28 +0000
You didn’t tell us what version of stream you are using.  It is building OK for me on Windows.
From: [email protected] <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Thursday, December 20, 2018 1:38 PM
To: '[email protected]' <[email protected]>
Subject: Stream fails on windows-x64 against base-7.0.2
I am using:
Windows 10 Pro
Visual Studio 2010 Professional
Make 4.2.1 (from the EPICS web site)
Strawberry perl (v5.28.1.1)
This issue is similar to:
https://github.com/epics-modules/softGlue/issues/1
and
https://github.com/epics-modules/sscan/issues/3
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64      -out:stream.dll -implib:stream.lib     DebugInterface.obj DummyInterface.obj AsynDriverInterface.obj EnumConverter.obj BCDConverter.obj RawConverter.obj RawFloatConverter.obj BinaryConverter.obj ChecksumConverter.obj MantissaExponentConverter.obj TimestampConverter.obj devaoStream.obj devaiStream.obj devboStream.obj devbiStream.obj devmbboStream.obj devmbbiStream.obj devmbboDirectStream.obj devmbbiDirectStream.obj devlongoutStream.obj devlonginStream.obj devstringoutStream.obj devstringinStream.obj devwaveformStream.obj devcalcoutStream.obj devaaiStream.obj devaaoStream.obj devscalcoutStream.obj StreamVersion.obj StreamBuffer.obj StreamError.obj StreamProtocol.obj StreamFormatConverter.obj StreamCore.obj StreamBusInterface.obj StreamEpics.obj      c:/epics/support/asyn/lib/windows-x64/asyn.lib  c:/epics/base-7.0.2/lib/windows-x64/dbRecStd.lib  c:/epics/base-7.0.2/lib/windows-x64/dbCore.lib  c:/epics/base-7.0.2/lib/windows-x64/ca.lib  c:/epics/base-7.0.2/lib/windows-x64/Com.lib
   Creating library stream.lib and object stream.exp
devaoStream.obj : error LNK2001: unresolved external symbol interruptAccept
devwaveformStream.obj : error LNK2001: unresolved external symbol pamapdbfType
StreamEpics.obj : error LNK2001: unresolved external symbol pdbbase
stream.dll : fatal error LNK1120: 3 unresolved externals
make[3]: *** [c:/epics/base-7.0.2/configure/RULES_BUILD:292: stream.dll] Error 1120
make[3]: Leaving directory 'C:/epics/support/stream/StreamDevice/src/O.windows-x64'
make[2]: *** [c:/epics/base-7.0.2/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/support/stream/StreamDevice/src'
make[1]: *** [c:/epics/base-7.0.2/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory 'C:/epics/support/stream/StreamDevice'
make: *** [configure/RULES_DIRS:88: StreamDevice.install] Error 2
Kaz
RE: Stream fails on windows-x64 against base-7.0.2 Gofron, Kazimierz via Tech-talk
Prev: Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Matt Newville via Tech-talk
Next: RE: Stream fails on windows-x64 against base-7.0.2 Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Stream fails on windows-x64 against base-7.0.2 Gofron, Kazimierz via Tech-talk
ANJ, 20 Dec 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
