Hi Russ, > perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm > Can't locate object method "new" via package "Pod::Simple::HTML" (perhaps you forgot to load "Pod::Simple::HTML"?) at ../../../src/tools/podToHtml.pl line 89. I think that means you need to install that Perl package. That should be ~:> cpan install POD::Simple::HTML or ~:> perl -MCPAN -e 'install Pod::Simple::HTML' That probably needs root privileges. --Matt
ANJ, 20 Dec 2018 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
