1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Stream fails on windows-x64 against base-7.0.2
From: Dirk Zimoch via Tech-talk <[email protected]>
To: "Gofron, Kazimierz" <[email protected]>, EPICS <[email protected]>
Date: Fri, 21 Dec 2018 12:10:16 +0100
Hello Kaz,
I had put some effort into making StreamDevice 2.8 compatible with Windows dynamic linking, which was a pain in the ass. I had tested everything with 3.16.1 and got no errors, only some strange warnings.
I have now again tested StreamDevice 2.8.8 with several versions of EPICS base. Here are my results:
R3.14.12.7: Success
R3.15.5: Success
R3.15.6: Success
R3.16.1: Success
R3.16.2: Success
R7.0.1.1: cannot build base
R7.0.2: cannot build base
Trying to build EPICS 7 in windows-x64 fails with:
D:\user\zimoch\base-7.0.2\bin\windows-x64\e_flex.exe: can't open skeleton file /cygdrive/d/user/zimoch/base-7.0.2/include/flex.skel.static Installing PERL_MODULES file /cygdrive/d/user/zimoch/base-7.0.2/lib/perl/EPICS/macLib.pm make[4]: *** No rule to make target 'asLib_lex.c', needed by 'asLib.c'. Stop. make[4]: Leaving directory '/cygdrive/d/user/zimoch/base-7.0.2/modules/libcom/src/O.windows-x64' make[3]: *** [/cygdrive/d/user/zimoch/base-7.0.2/configure/RULES_ARCHS:58: install.windows-x64] Error 2 make[3]: Leaving directory '/cygdrive/d/user/zimoch/base-7.0.2/modules/libcom/src' make[2]: *** [/cygdrive/d/user/zimoch/base-7.0.2/configure/RULES_DIRS:84: src.install] Error 2 make[2]: Leaving directory '/cygdrive/d/user/zimoch/base-7.0.2/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
make[1]: Leaving directory '/cygdrive/d/user/zimoch/base-7.0.2/modules'
make: *** [configure/RULES_DIRS:84: modules.install] Error 2
The same with 7.0.1.1. No idea what's wrong now. Building EPICS 3.16 was no problem at all.
I am using Windows 10 cmd.exe, Visual Studio 2017 cl, cygwin make and cygwin perl.
D:\user\zimoch\base-7.0.1.1>cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.14.26430 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
D:\user\zimoch\base-7.0.1.1>make -v
GNU Make 4.2.1
Built for i686-pc-cygwin
Copyright (C) 1988-2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
D:\user\zimoch\base-7.0.1.1>perl -v
This is perl 5, version 22, subversion 2 (v5.22.2) built for cygwin-thread-multi-64int
Copyright 1987-2015, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl".  If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
Dirk
On 20.12.2018 20:37, Gofron, Kazimierz via Tech-talk wrote:
I am using:
Windows 10 Pro
Visual Studio 2010 Professional
|Make 4.||2.||1 (from the EPICS web site)|
|Strawberry perl ||(v5.28.1.1)|
This issue is similar to:
https://github.com/epics-modules/softGlue/issues/1
and
https://github.com/epics-modules/sscan/issues/3
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64      -out:stream.dll -implib:stream.lib DebugInterface.obj DummyInterface.obj AsynDriverInterface.obj EnumConverter.obj BCDConverter.obj RawConverter.obj RawFloatConverter.obj BinaryConverter.obj ChecksumConverter.obj MantissaExponentConverter.obj TimestampConverter.obj devaoStream.obj devaiStream.obj devboStream.obj devbiStream.obj devmbboStream.obj devmbbiStream.obj devmbboDirectStream.obj devmbbiDirectStream.obj devlongoutStream.obj devlonginStream.obj devstringoutStream.obj devstringinStream.obj devwaveformStream.obj devcalcoutStream.obj devaaiStream.obj devaaoStream.obj devscalcoutStream.obj StreamVersion.obj StreamBuffer.obj StreamError.obj StreamProtocol.obj StreamFormatConverter.obj StreamCore.obj StreamBusInterface.obj StreamEpics.obj      c:/epics/support/asyn/lib/windows-x64/asyn.lib c:/epics/base-7.0.2/lib/windows-x64/dbRecStd.lib c:/epics/base-7.0.2/lib/windows-x64/dbCore.lib c:/epics/base-7.0.2/lib/windows-x64/ca.lib c:/epics/base-7.0.2/lib/windows-x64/Com.lib
    Creating library stream.lib and object stream.exp
devaoStream.obj : error LNK2001: unresolved external symbol interruptAccept
devwaveformStream.obj : error LNK2001: unresolved external symbol pamapdbfType
StreamEpics.obj : error LNK2001: unresolved external symbol pdbbase
stream.dll : fatal error LNK1120: 3 unresolved externals
make[3]: *** [c:/epics/base-7.0.2/configure/RULES_BUILD:292: stream.dll] Error 1120
make[3]: Leaving directory 'C:/epics/support/stream/StreamDevice/src/O.windows-x64'
make[2]: *** [c:/epics/base-7.0.2/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/support/stream/StreamDevice/src'
make[1]: *** [c:/epics/base-7.0.2/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory 'C:/epics/support/stream/StreamDevice'
make: *** [configure/RULES_DIRS:88: StreamDevice.install] Error 2
Kaz
Re: Stream fails on windows-x64 against base-7.0.2 Mark Rivers via Tech-talk
Stream fails on windows-x64 against base-7.0.2 Gofron, Kazimierz via Tech-talk
Prev: Error when trying to build Sample IOC Application Harshal Sheth via Tech-talk
Next: Re: Stream fails on windows-x64 against base-7.0.2 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: RE: Stream fails on windows-x64 against base-7.0.2 Mark Rivers via Tech-talk
ANJ, 21 Dec 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
