Hi Kaz,
I have been using the 2.7.7 release. I just updated to the current master branch.
It built fine for me with base 7.0.2 and Visual Studio 2015 with windows-x64 (dynamic) build.
I then tested with Visual Studio 2010, which is what you are using. It fails for me, but with a very different error than you are getting:
cl -EHsc -GR -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -DUSE_TYPED_RSET -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IJ:/epics/devel/asyn-4-33/include -IJ:/epics/devel/calc-3-7/include -IJ:/epics/devel/sscan-2-11-1/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc
-IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -c ../DebugInterface.cc
DebugInterface.cc
j:\epics\devel\stream\streamdevice\src\streambusinterface.h(29) : error C2051: case _expression_ not constant
j:\epics\devel\stream\streamdevice\src\streambusinterface.h(29) : warning C4065: switch statement contains 'default' but no 'case' labels
make[3]: *** [H:/epics-devel/base-7.0.2/configure/RULES_BUILD:239: DebugInterface.obj] Error 2
make[3]: Leaving directory 'J:/epics/devel/stream/StreamDevice/src/O.windows-x64-vs2010'
make[2]: *** [H:/epics-devel/base-7.0.2/configure/RULES_ARCHS:58: install.windows-x64-vs2010] Error 2
make[2]: Leaving directory 'J:/epics/devel/stream/StreamDevice/src'
make[1]: *** [H:/epics-devel/base-7.0.2/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory 'J:/epics/devel/stream/StreamDevice'
make: *** [configure/RULES_DIRS:88: StreamDevice.install] Error 2
I believe this is because the ENUM macro defined in MacroMagic.h does not work on VS 2010.
Are you sure you are really on the master branch?
I then did the following, so I was on the latest tagged version with a few patches.
cd StreamDevice
git checkout stream_2_7_7
I then applied these patches which I had previously determined were necessary:
corvette:stream/StreamDevice/src>git diff stream_2_7_7
diff --git a/src/StreamBuffer.cc b/src/StreamBuffer.cc
index 3b34de3..6e25f7e 100644
--- a/src/StreamBuffer.cc
+++ b/src/StreamBuffer.cc
@@ -314,7 +314,7 @@ dump() const
StreamBuffer result(256+cap*5);
result.append("\033[0m");
size_t i;
- result.print("%"P"d,%"P"d,%"P"d:\033[37m", offs, len, cap);
+ result.print("%" P "d,%" P "d,%" P "d:\033[37m", offs, len, cap);
for (i = 0; i < cap; i++)
if (i == offs) result.append("\033[34m[\033[0m");
diff --git a/src/StreamBuffer.h b/src/StreamBuffer.h
index a016089..e4cb6a6 100644
--- a/src/StreamBuffer.h
+++ b/src/StreamBuffer.h
@@ -23,6 +23,8 @@
#include <string.h>
#include <stdlib.h>
+#include <sys/types.h>
#ifndef __GNUC__
#define __attribute__(x)
#endif
diff --git a/src/StreamCore.cc b/src/StreamCore.cc
index 1943bf1..ca59b6a 100644
--- a/src/StreamCore.cc
+++ b/src/StreamCore.cc
@@ -997,7 +997,7 @@ readCallback(StreamIoStatus status,
finishProtocol(ReplyTimeout);
return 0;
case StreamIoFault:
- error("%s: I/O error after reading %"P"d byte%s: \"%s%s\"\n",
+ error("%s: I/O error after reading %" P "d byte%s: \"%s%s\"\n",
name(),
inputBuffer.length(), inputBuffer.length()==1 ? "" : "s",
inputBuffer.length() > 20 ? "..." : "",
@@ -1006,7 +1006,7 @@ readCallback(StreamIoStatus status,
return 0;
inputBuffer.append(input, size);
- debug("StreamCore::readCallback(%s) inputBuffer=\"%s\", size %"P"d\n",
+ debug("StreamCore::readCallback(%s) inputBuffer=\"%s\", size %" P "d\n",
name(), inputBuffer.expand()(), inputBuffer.length());
if (*activeCommand != in_cmd)
diff --git a/src/devaiStream.c b/src/devaiStream.c
index 7fc92cc..5741e05 100644
--- a/src/devaiStream.c
+++ b/src/devaiStream.c
@@ -19,17 +19,12 @@
#include <math.h>
+#include <epicsMath.h>
#include <menuConvert.h>
#include <aiRecord.h>
#include "devStream.h"
#include <epicsExport.h>
-#ifdef vxWorks
-#include <private/mathP.h>
-#define isinf(x) isInf(x)
-#define isnan(x) isNan(x)
-#endif
static long readData (dbCommon *record, format_t *format)
aiRecord *ai = (aiRecord *) record;
That built fine both on VS 2015 and on VS 2010.
Stream master release, cloned today.
C:\epics\support\stream>git branch
* master
You didn’t tell us what version of stream you are using. It is building OK for me on Windows.
I am using:
Windows 10 Pro
Visual Studio 2010 Professional
Make 4.2.1 (from the EPICS web site)
Strawberry perl (v5.28.1.1)
This issue is similar to:
https://github.com/epics-modules/softGlue/issues/1
and
https://github.com/epics-modules/sscan/issues/3
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release -MACHINE:X64 -out:stream.dll -implib:stream.lib DebugInterface.obj DummyInterface.obj AsynDriverInterface.obj EnumConverter.obj BCDConverter.obj RawConverter.obj
RawFloatConverter.obj BinaryConverter.obj ChecksumConverter.obj MantissaExponentConverter.obj TimestampConverter.obj devaoStream.obj devaiStream.obj devboStream.obj devbiStream.obj devmbboStream.obj devmbbiStream.obj devmbboDirectStream.obj devmbbiDirectStream.obj
devlongoutStream.obj devlonginStream.obj devstringoutStream.obj devstringinStream.obj devwaveformStream.obj devcalcoutStream.obj devaaiStream.obj devaaoStream.obj devscalcoutStream.obj StreamVersion.obj StreamBuffer.obj StreamError.obj StreamProtocol.obj StreamFormatConverter.obj
StreamCore.obj StreamBusInterface.obj StreamEpics.obj c:/epics/support/asyn/lib/windows-x64/asyn.lib c:/epics/base-7.0.2/lib/windows-x64/dbRecStd.lib c:/epics/base-7.0.2/lib/windows-x64/dbCore.lib c:/epics/base-7.0.2/lib/windows-x64/ca.lib c:/epics/base-7.0.2/lib/windows-x64/Com.lib
Creating library stream.lib and object stream.exp
devaoStream.obj : error LNK2001: unresolved external symbol interruptAccept
devwaveformStream.obj : error LNK2001: unresolved external symbol pamapdbfType
StreamEpics.obj : error LNK2001: unresolved external symbol pdbbase
stream.dll : fatal error LNK1120: 3 unresolved externals
make[3]: *** [c:/epics/base-7.0.2/configure/RULES_BUILD:292: stream.dll] Error 1120
make[3]: Leaving directory 'C:/epics/support/stream/StreamDevice/src/O.windows-x64'
make[2]: *** [c:/epics/base-7.0.2/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/support/stream/StreamDevice/src'
make[1]: *** [c:/epics/base-7.0.2/configure/RULES_DIRS:84: src.install] Error 2
make[1]: Leaving directory 'C:/epics/support/stream/StreamDevice'
Kaz
