1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
To: "'Peterson, Kevin M.'" <[email protected]>
Cc: "Woods, Russell" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Dec 2018 15:19:02 +0000
My system has no perl environment variables set:
/home/epics> printenv | grep PERL
/home/epics>
I just realized what one difference could  be.  I am building all architectures in the same tree on a Centos 7 system.  I built the linux-x86-64 architecture first, which is the Centos 7 EPICS_HOST_ARCH.  I then built the older linux-x86_64-gcc42 architecture, which is the one for the Pilatus.  Since the html documentation had already been built on the newer architecture "make" was probably smart enough to not try to build it again on the old architecture.  Thus I may have the problem but would only see it if I built first on linux-x86_64-gcc42.
-----Original Message-----
Sent: Friday, December 21, 2018 8:51 AM
Cc: [email protected]; Woods, Russell <[email protected]>
Subject: Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
Have you confirmed that the perl environment variables are the same?
Kevin
On 12/20/18 4:01 PM, Mark Rivers via Tech-talk wrote:
> This thread moved off tech-talk for a while, but I'm putting it back
> in case someone has ideas.
> My system and Russ' appear to be the same, but he gets the error and I
> don't.
> Mark
RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Woods, Russell via Tech-talk
RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
Prev: Re: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Peterson, Kevin M. via Tech-talk
Next: RE: FW: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
