1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting data from a shell script into an ioc
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Bo Jakobsen <[email protected]>
Cc: techtalk <[email protected]>
Date: Tue, 15 Jan 2019 13:43:50 +0000
> I will consider the phyton solutions, but I agree the cronjob is an easy and elegant solution.
A cron job that periodically fetches your data and then calls `caput SomeRecord ThatData` is certainly a very easy way to get started. It's perfectly fine if you run that cronjob once an hour.
It would be bad to run such a setup every few seconds, because each call to caput will send a name search, establish the network connection, write a value, disconnect, ... and then do the same a second later.
For that scenario, a python script that uses PyEpics as a client would be much better:
from time import sleep
from epics import caput
while True:
    # .. somehow get your data ..
    caput('SomePV', that_data)
    sleep(1)
The Pyepics `caput` will under the hood only connect once and then keep reusing that connection.
Or look at PCASPY to create a CA server in python.
Kay
Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
Re: Getting data from a shell script into an ioc Pearson, Matthew R. via Tech-talk
Re: Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
Prev: Problem in Stream Out of two 8 bit data Ashish Sharma via Tech-talk
Next: EPICS in Docker containers Gabriel de Souza Fedel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Getting data from a shell script into an ioc Bo Jakobsen via Tech-talk
Next: Re: Getting data from a shell script into an ioc Sebastian Marsching via Tech-talk
ANJ, 23 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
