1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: calc record odd behavior
From: Bruno Martins via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 29 Jan 2019 11:09:13 -0500
I noticed something odd when using the calc record. This is the database I have:
record(ai, "A") {
  field(PINI, "YES")
  field(VAL,  "1")
record(calc, "CALC") {
    field(INPA, "A")
    field(CALC, "A")
    field(SCAN, "1 second")
CALC's value is initially 1, as expected. However, if I do "caput CALC 0", a monitor event is never issued again when CALC.VAL goes back to being 1. Shouldn't a monitor event be issued in this case?
Tested with Base R7.0.1.2-DEV and R3.15.3-13.
Bruno
Re: calc record odd behavior Johnson, Andrew N. via Tech-talk
Prev: RE: Support for GBS MCA527 Mark Rivers via Tech-talk
Next: Re: Support for GBS MCA527 Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Keithley 3390 Arbitrary Waveform Generator gary.yendell--- via Tech-talk
Next: Re: calc record odd behavior Johnson, Andrew N. via Tech-talk
ANJ, 29 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
