1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: trying to find information on mvme5100 battery
From: Dirk Zimoch via Tech-talk <[email protected]>
To: <[email protected]>
Date: Mon, 11 Feb 2019 10:53:39 +0100
Ehm... I screwed up the file names. The chip Name is like "M48T37" and the file and function names should have matched. Sorry. Here are the fixed files.
Dirk
On 11.02.19 10:43, Dirk Zimoch via Tech-talk wrote:
Hi Maren,
Attached find my driver for the M48T37 Timekeeper battery status. It works with any EPICS version on MVME51xx as well as on MVME23xx, maybe on more boards using this chip.
I have some more code to read and set the RTC and use the alarm function of the M48T37 in case you need it.
The code is vxWorks only.
Be aware that the M48T37 reads the battery status only once at power-on. So there is no point in processing the record more often than PINI=YES.
Dirk
On 09.02.19 02:06, Maren Purves wrote:
Happy to, thanks Dirk!
On 2/8/19 05:35, Dirk Zimoch via Tech-talk wrote:
I am just now writing a driver for it. Wait a few days please...
On 08.02.19 03:01, Maren Purves via Tech-talk wrote:
Hi all,
I'm working on some monitoring stuff for a new receiver
and as the new receiver isn't here yet I just got a spare
mvme5100 board. Trying to boot it I found that it had
'forgotten' its boot parameters. It is supposed to have
a replaceable battery and we found on part that looks like
it may be a battery but with no part number or anything on
it.
None of the manuals I found on-line has a board layout
with labels on it that would tell me where the battery
is (assuming that the battery is the problem), or had
any specifications for it.
Pulling out another spare board, it behaved the same way.
If we have to put any of these spare boards into use that
would mean that they would have to have their boot parameters
reinstalled each time we have a power glitch. That's OK
for us here in the office/lab but not OK for people
operating telescopes at night.
Does anybody know and can either point me somewhere where
to find this information - or have the information and
pass it on?
Thanks in advance,
Maren Purves
East Asian Observatory
#include <vxWorks.h>
#include "epicsVersion.h"
#include "devSup.h"
#include "biRecord.h"
#define M48T_FLAGS    0x7ff0
#define M48T_FLAG_BAT   0x10
extern UCHAR sysNvRead(ULONG);
long M48T37ReadBatteryLow(biRecord *rec)
    rec->rval = sysNvRead(M48T_FLAGS) & M48T_FLAG_BAT ? 1 : 0;
    return 0;
struct {
    long        number;
    DEVSUPFUN   report;
    DEVSUPFUN   init;
    DEVSUPFUN   init_record;
    DEVSUPFUN   get_ioint_info;
    DEVSUPFUN   read;
} M48T37BatteryLow = {
    5,
    NULL,
    NULL,
    NULL,
    NULL,
#ifndef BASE_VERSION
#include "epicsExport.h"
epicsExportAddress(dset, M48T37BatteryLow);
#endif
device(bi,         INST_IO, M48T37BatteryLow,  "M48T37BatteryLow")
record (bi, "$(IOC):BATTERY")
    field(DTYP, "M48T37BatteryLow")
    field(PINI, "YES") # battery status uptates at power-on only
    field(ZNAM, "OK")
    field(ONAM, "LOW")
    field(OSV,  "MINOR")
Re: trying to find information on mvme5100 battery Dirk Zimoch via Tech-talk
Re: trying to find information on mvme5100 battery Maren Purves via Tech-talk
Prev: Re: trying to find information on mvme5100 battery Dirk Zimoch via Tech-talk
Next: Re: trying to find information on mvme5100 battery Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
ANJ, 11 Feb 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
