1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream device - parsing array of pairs of floats
From: Dirk Zimoch via Tech-talk <[email protected]>
To: <[email protected]>
Date: Fri, 15 Feb 2019 10:58:22 +0100
I tested it and it hung up my ioc. Seems I have a bug in regsub.
On 15.02.19 09:55, Dirk Zimoch via Tech-talk wrote:
Unfortunately StreamDevice cannot easily parse such interlaced arrays at the moment.
Maybe the following works:
For the values:
Separator=",";
in "%#/[.0-9]+|//%f";
For the Timestamps:
Separator=",";
in "%#/|[.0-9E+-]+//%f";
%#/regexp/subs/ is the regular expression pre-processor, here removing the "other" array from the input. Performance may be not so good and scales like O(n²) with the array length because of all the copying involved.
One of the records should be active having the 'out' command that produces the reply. The other should be "I/O Intr" reading the time stamps passively.
Not tested. Hope it works.
Dirk
On 14.02.19 18:35, Joao Afonso via Tech-talk wrote:
Hello,
I have a string returned by a device, representing an array where each element is a pair <time, value>:
- each pair is separated by "|": <timestamp>|<value>
- each element of the array separated by ","
- all values are floats
- the timestamp increment may not be linear (that is why it needs to be recorded)
Example
0.1000|0.1230000E+00,0.2000|0.4560000E+00,0.3000|0.7890000E+00, [...]
Is it possible to parse this using stream device (into two waveform records)?
Or do I have to use something more powerful such as asynDriver?
I have seen several examples, but only with using simple type elements, not like this.
As a followup, is it possible to do the inverse, merging two waveform records into a string?
Thank you in advance,
Joao
CERN TE-EPC-CCS
Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
Stream device - parsing array of pairs of floats Joao Afonso via Tech-talk
Prev: Re: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Next: Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream device - parsing array of pairs of floats Dirk Zimoch via Tech-talk
ANJ, 15 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
