1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: AreaDetector OCR plugin
From: Rod Nussbaumer via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 15 Feb 2019 07:20:42 -0800
All:
Has anyone developed an Optical Character Recognition plugin for AreaDetector? The potential use case is to have a camera aimed at an instrument front panel, and digitize the display to extract the instrument's displayed output. I've already anticipated the potential problems associated with multiplexed displays that may introduce artifacts into the digitized images, so I don't want to attempt to develop something that may be a failure anyway.
Are there any classes of inexpensive low resolution cameras supported by AreaDetector? Like consumer grade webcams, for instance?
Yes, it's a hack, but easier than the alternatives in at least one known case.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
RE: AreaDetector OCR plugin Heesterman, Peter J via Tech-talk
Re: AreaDetector OCR plugin Michael Davidsaver via Tech-talk
Prev: Re: archiverAppliance access to Shankar, Murali via Tech-talk
Next: RE: How fast can EPICS communicate with a device? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How fast can EPICS communicate with a device? Sobhani, Bayan via Tech-talk
Next: RE: AreaDetector OCR plugin Heesterman, Peter J via Tech-talk
ANJ, 15 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
