1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector OCR plugin
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Rod Nussbaumer <[email protected]>, [email protected]
Date: Fri, 15 Feb 2019 19:57:53 -0800
On 2/15/19 7:20 AM, Rod Nussbaumer via Tech-talk wrote:
> All:
> Has anyone developed an Optical Character Recognition plugin for AreaDetector? The potential use case is to have a camera aimed at an instrument front panel, and digitize the display to extract the instrument's displayed output. I've already anticipated the potential problems associated with multiplexed displays that may introduce artifacts into the digitized images, so I don't want to attempt to develop something that may be a failure anyway.
Do you have an OCR software in mind?
I investigated this a couple of years ago and the only functional FOSS
entrant seemed to be:
https://github.com/tesseract-ocr/tesseract
Which does an acceptable job with scans of printed documents
with small rotations.
> Are there any classes of inexpensive low resolution cameras supported by AreaDetector? Like consumer grade webcams, for instance?
> Yes, it's a hack, but easier than the alternatives in at least one known case.
I look forward to hearing how this works out!
AreaDetector OCR plugin Rod Nussbaumer via Tech-talk
Prev: RE: Problems with StreamDevice Mark Rivers via Tech-talk
Next: Re: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: AreaDetector OCR plugin Heesterman, Peter J via Tech-talk
Next: RE: AreaDetector OCR plugin Wlodek, Jakub via Tech-talk
ANJ, 18 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
