1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Problems with StreamDevice
From: Dirk Zimoch via Tech-talk <[email protected]>
Date: Mon, 18 Feb 2019 11:24:32 +0100
 2)      If I have an error in my protocol file I am not seeing any error messages.  I used to see them in previous versions.
If I break the protocol by changing CHN to CHAN
readChans {
   out "CHAN:?";
   in "CHAN:%d";
then this is what I see with asynTrace on.  Note that the CHAN:? command returned NAK:00 which the protocol won’t parse.
This is of course a perfectly valid protocol. Thus the protocol parser would not write any errors. Only your device cannot handle it. Switch on "var streamError 1" and you will see the messages you are looking for.
The idea was to turn on errors during commissioning of a new device to see any wrong protocols and such, but leave it turned off later during normal operation and only use check record severity and status.
Dirk
On 15.02.19 20:46, Mark Rivers wrote:
Hi Dirk,
Thanks for the reply.
Are there release notes for StreamDevice somewhere?  I cannot find them on Github or on the PSI web site.  This change in error behavior seems to me something that should be documented.
I think the protocol error reporting is not fixed in 2.8.8.
ØI always wanted to rework the error and debug message system, in particular to allow filtering per record, but I never found the time.
I suggested some time back that it would be good for streamDevice to print messages using ASYN_TRACE_ERROR, ASYN_TRACE_FLOW, and ASYN_TRACEIO_DEVICE for the underlying asyn port.  Then at least users have control over the error and debugging information on a per-port basis.  I understand that the core of Stream is intended to be independent of asyn.  But in practice I think only asyn is used?  The error handling could be made to hide asyn, so that is uses asyn if available, and something else if not.
*Sent:* Friday, February 15, 2019 1:20 PM
*To:* Mark Rivers <[email protected]>
*Cc:* [email protected]
*Subject:* Re: Problems with StreamDevice
People here at PSI had complained about error message flooding when devices go crazy or are offline. Softiocs had filled their disks with logs and such.
Thus I have heavily reduced the amount of error output.
StreamDevice sets asynTraceMask to 0. This has already been reported as a bug arguing it is not StreamsDevice‘s responsibility to silence other code. And it does so in iocInit, so that user settings in the startup script are ignored. I am somewhat convinced that this is a valid argument and will change it soon.
StreamDevice suppresses its own error messages by default now. You can re-enable error messages with var streamError 1.
In the first 2.8 versions this also suppressed parsing errors which was very inconvenient. This should not happen any more. Errors are enabled while reading the protocol file. I will check in which version this is the case on Monday. But I thought this was already fixed in 2.8.8. I always wanted to rework the error and debug message system, in particular to allow filtering per record, but I never found the time.
Dirk
Am 15.02.2019 um 19:17 schrieb Mark Rivers <[email protected] <mailto:[email protected]>>:
    I am running StreamDevice 2.8.8.  I am having 3 issues.  I don’t
    know if these are bugs or features, because I cannot find the
    release notes for StreamDevice.  Where are they located?
    1)StreamDevice seems to set asynTraceMask to 0 for the port.
    This is my startup script.
    < envPaths
    # Tell EPICS all about the record types, device-support modules,
    drivers,
    # etc. in this build from CARS
    dbLoadDatabase("../../dbd/CARSLinux.dbd")
    CARSLinux_registerRecordDeviceDriver(pdbbase)
    drvAsynIPPortConfigure("PORT","gse-tetramm2:10001",0,0,0)
    asynOctetSetInputEos(PORT, 0, "\r\n")
    asynOctetSetOutputEos(PORT, 0, "\r")
    asynSetTraceIOMask(PORT, 0, 2)
    asynSetTraceMask(PORT, 0, 9)
    asynSetOption(PORT, 0, "disconnectOnReadTimeout", "Y")
    dbLoadRecords("stream2.db", "P=13TEST:, R=R:, PORT=PORT")
    dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=13TEST:, R=asyn1,
    PORT=PORT, ADDR=0, IMAX=80, OMAX=80")
    iocInit
Note that it sets the trace mask to 9 with asynSetTraceMask. However, when I boot and look at the trace mask with asynReport it
    is 0.  The TraceIOMask is 2 like I set it, but the traceMask is 0.
    epics> asynReport 10
    PORT multiDevice:No canBlock:Yes autoConnect:Yes
         enabled:Yes connected:Yes numberConnects 1
         nDevices 0 nQueued 0 blocked:No
         asynManagerLock:No synchronousLock:No
         exceptionActive:No exceptionUsers 5 exceptionNotifys 0
         traceMask:0x0 traceIOMask:0x2 traceInfoMask:0x1
         interposeInterfaceList
             asynOctet pinterface 0x1da89e0 drvPvt 0x3624870
         interfaceList
             asynCommon pinterface 0x1ce6770 drvPvt 0x3620c10
             asynOption pinterface 0x1ce6790 drvPvt 0x3620c10
             asynOctet pinterface 0x3620d30 drvPvt 0x3620c10
         Port gse-tetramm2:10001: Connected
                         fd: 5
         Characters written: 152
            Characters read: 208
    If I uncomment the line that loads the StreamDevice records then
    asynTrace is set correctly when I boot.
    #dbLoadRecords("stream2.db", "P=13TEST:, R=R:, PORT=PORT")
         exceptionActive:No exceptionUsers 2 exceptionNotifys 0
         traceMask:0x9 traceIOMask:0x2 traceInfoMask:0x1
             asynOctet pinterface 0x1da89e0 drvPvt 0x2c6b830
         interfaceList
             asynCommon pinterface 0x1ce6770 drvPvt 0x2c67bd0
             asynOption pinterface 0x1ce6790 drvPvt 0x2c67bd0
             asynOctet pinterface 0x2c67cf0 drvPvt 0x2c67bd0
                         fd: 6
         Characters written: 0
            Characters read: 0
    If I put the asynSetTraceMask after iocInit it works.  Is this
    indeed something StreamDevice is doing?
    2)If I have an error in my protocol file I am not seeing any error
    This is what the protocol should be, command is CHN.
    readChans {
        out "CHN:?";
        in "CHN:%d";
    readChans {
        out "CHAN:?";
        in "CHAN:%d";
    2019/02/15 12:07:15.074 gse-tetramm2:10001 write 7
    CHAN:?\r
    2019/02/15 12:07:15.075 gse-tetramm2:10001 read 8
    NAK:00\r\n
    2019/02/15 12:07:15.077 gse-tetramm2:10001 write 6
    HVV:?\r
    2019/02/15 12:07:15.078 gse-tetramm2:10001 read 10
    HVV:0.00\r\n
    The record is indeed in invalid alarm but I don’t see any error
    messages from StreamDevice (STAT=CALC, SEVR=INVALID).  Is this new
    behavior to see no errors?
    epics> dbpr 13TEST:R:Chans 3
    ACKS: INVALID       ACKT: YES           ADEL: 0             AFTC: 0
    AFVL: 0             ALST: 0             AOFF: 0             ASG :
    ASLO: 1             BKPT: 00            DESC:               DISA: 0
    DISP: 0             DISS: NO_ALARM      DISV: 1             DTYP: stream
    EGU :               EGUF: 0             EGUL: 0             EOFF: 0
    ESLO: 1             EVNT:               FLNK: CONSTANT      HHSV:
    NO_ALARM
    HIGH: 0             HIHI: 0             HOPR: 0             HSV :
    NO_ALARM
    HYST: 0             INIT: 0
    INP : INST_IO @stream2.proto readChans PORT 0 0             LALM: 0
    LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV:
    NO_ALARM
    LOLO: 0             LOPR: 0             LOW : 0             LSV :
    NO_ALARM
    MDEL: 0             MLST: 0             NAME: 13TEST:R:Chans
    NSEV: NO_ALARM      NSTA: NO_ALARM      ORAW: 0             PACT: 0
    PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
    PROC: 0             PUTF: 0             ROFF: 0             RPRO: 0
    RVAL: 0             SCAN: 1 second      SDIS: CONSTANT      SDLY: -1
    SEVR: INVALID       SIML: CONSTANT      SIMM: NO            SIMS:
    NO_ALARM
    SIOL: CONSTANT      SMOO: 0             SSCN: <nil>         STAT: CALC
    SVAL: 0             TIME: 2019-02-15 12:10:16.524791659     TPRO: 0
    TSE : 0             TSEL: CONSTANT      UDF : 1             UDFS:
    INVALID
    VAL : 0
3)If I have a communications error I don’t see any error messages. I used to see them in previous versions.  This is what I see when I
    disconnect the cable to my device.
    2019/02/15 12:12:18.494 gse-tetramm2:10001 read 10
    HVV:0.00\r\n
    2019/02/15 12:12:19.488 gse-tetramm2:10001 write 7  CABLE DISCONNECTED
    TEMP:?\r
    2019/02/15 12:12:36.488 gse-tetramm2:10001 write 7
    TEMP:?\r
    2019/02/15 12:12:36.489 gse-tetramm2:10001 read 9
    There are no error messages from StreamDevice.  This is with
    disconnectOnReadTimeout=Y, but there are no messages with that not
    set either.
Problems with StreamDevice Mark Rivers via Tech-talk
Re: Problems with StreamDevice Zimoch Dirk (PSI) via Tech-talk
RE: Problems with StreamDevice Mark Rivers via Tech-talk
Prev: Re: How to detect AsynIPPort disconnect? Dirk Zimoch via Tech-talk
Next: Re: Problems with StreamDevice Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: RE: Problems with StreamDevice Mark Rivers via Tech-talk
ANJ, 18 Feb 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
