1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about rdb channel archive
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 20 Feb 2019 16:23:27 +0100
Dear Zhefu,
I don't know it the monitor threshold within the archive engine works the same as the ADEL field within EPICS records.
For EPICS PVs, to send everything even if there is no change, the ADEL field should be '-1'. '0' means at least 1 bit in VAL has to change.
Hope this helps.
Best regards,
Florian
On 2/20/19 4:11 PM, lzf neu via Tech-talk wrote:
Dear Dr. Kay,
For special purposes, I intend to let the archive engine write real time data to database every monitor period (my period is 1.0s), irrespective of whether the real time data changed.
I tried to set the XML configuration file for a monitor with engine enforced value change threshold of 0.0 as follows:
<channel>
<name>NSV:P2</name>
<period>1.0</period>
<monitor>0.0</monitor></channel>
However, I faild. I have no idea how to achieve the goal. Any help will be appreciated and thanks in advance.
Zhefu
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Question about rdb channel archive lzf neu via Tech-talk
Prev: RE: print all information about a PV including units Mark Rivers via Tech-talk
Next: Re: print all information about a PV including units Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Question about rdb channel archive lzf neu via Tech-talk
Next: GNU Screen or procServ on ARM? John Dobbins via Tech-talk
ANJ, 21 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
