1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: EPICS Base compile failure on Windows-x64
From: Carl Willis via Tech-talk <[email protected]>
Date: Sun, 24 Feb 2019 12:18:31 -0700
Well, gnumake 4.2.1 gives me the following error:
configure/RULES_TOP:2: /c/epics/base-7.0.2/configure/RULES_TOP: No such file or directory
-Carl
On Sun, Feb 24, 2019 at 6:42 AM Mark Rivers <[email protected]> wrote:
Hi Carl,
I have built base 7.0.2 on Windows 10 with Community Edition 2017. I use the version of gnumake 4.2.1 from the link on this page:
https://epics.anl.gov/base/win32.php
I suggest you try that version of make.
Sent from my iPhone
On Feb 24, 2019, at 2:56 AM, Carl Willis via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
When attempting to build Epics Base v7.0.2 on Windows 10 using make from msys2 (or other sources) and Visual Studio 2017 Community Edition, this type of error keeps appearing:
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251     -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING    -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/c/epics/base-7.0.2/include/compiler/msvc -I/c/epics/base-7.0.2/include/os/WIN32 -I/c/epics/base-7.0.2/include -I/c/epics/base-7.0.2/include/compiler/msvc -I/c/epics/base-7.0.2/include/os/WIN32 -I/c/epics/base-7.0.2/include        -c ../../src/osi/os/WIN32/epicsTempFile.cpp
epicsTempFile.cpp
c1xx: fatal error C1083: Cannot open source file: '../../src/osi/os/WIN32/epicsTempFile.cpp': No such file or directory
Following the error, I identify the compiler as follows:
C:\epics\base-7.0.2>cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.16.27027.1 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
My startup script has the following:
rem Set the environment for Microsoft Visual Studio
call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" x64
In other words, the startup script correctly identifies the compiler, but a needed file appears to be missing (??)
Can anyone identify my error or issue?
Thanks
Carl Willis
RE: EPICS Base compile failure on Windows-x64 Mark Rivers via Tech-talk
EPICS Base compile failure on Windows-x64 Carl Willis via Tech-talk
Re: EPICS Base compile failure on Windows-x64 Mark Rivers via Tech-talk
Prev: Re: EPICS Base compile failure on Windows-x64 Mark Rivers via Tech-talk
Next: RE: EPICS Base compile failure on Windows-x64 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 24 Feb 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
