1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: RE: EPICS Base compile failure on Windows-x64
To: 'Carl Willis' <[email protected]>
Date: Sun, 24 Feb 2019 20:08:06 +0000
Hi Carl,
Do you know why it is giving you that Linux-like path syntax: “/c/epics/…”?  You are using the Windows cmd shell, right?
I have attached the Windows batch files I use to configure my PATH and the Visual Studio settings.  I have renamed them from .bat to .txt to get them through the mail system.  I just all setup_epics_vs2017_win64.bat in my cmd shell when it is created.  It calls setup_epics_path.bat.
This is setup_epics_path.bat
rem This file sets the path for builds
set PATH=C:\Program Files\GNU make;^
C:\Program Files\re2c;^
C:\Perl64\bin;^
H:\epics\base\bin\windows-x64-static;^
H:\epics\extensions\bin\windows-x64-static;^
%PATH%
C:\Program Files\GNU make\ is where I installed gnumake 4.2.1. from the EPICS Web page.
re2c is needed for the sequencer.
C:\Perl64 is where Perl was installed.
The paths to base\bin and base\extensions are not needed for the build, but are useful for utilities.
This is the beginning of what I see when I run “make –sj clean” and then “make” in EPICS base-7.0.2.
H:\epics-devel\base-7.0.2>make -sj clean
make -C ./configure install
make[1]: Entering directory 'H:/epics-devel/base-7.0.2/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64-static-vs2017 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../.. \
    T_A=windows-x64-static-vs2017 install
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/configure/O.windows-x64-static-vs2017'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'H:/epics-devel/base-7.0.2/configure/O.windows-x64-static-vs2017'
make[1]: Leaving directory 'H:/epics-devel/base-7.0.2/configure'
make -C ./src install
make[1]: Entering directory 'H:/epics-devel/base-7.0.2/src'
make -C ./tools install
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64-static-vs2017 ../../..
make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/src/tools/O.windows-x64-static-vs2017'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory 'H:/epics-devel/base-7.0.2/src/tools/O.windows-x64-static-vs2017'
make[2]: Leaving directory 'H:/epics-devel/base-7.0.2/src/tools'
make -C template/base install
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/src/template/base'
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/makeMakefile.pl O.windows-x64-static-vs2017 ../../../..
make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/src/template/base/O.windows-x64-static-vs2017'
make[3]: Leaving directory 'H:/epics-devel/base-7.0.2/src/template/base/O.windows-x64-static-vs2017'
make[2]: Leaving directory 'H:/epics-devel/base-7.0.2/src/template/base'
make -C template/ext install
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/src/template/ext'
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/src/template/ext/O.windows-x64-static-vs2017'
make[3]: Leaving directory 'H:/epics-devel/base-7.0.2/src/template/ext/O.windows-x64-static-vs2017'
make[2]: Leaving directory 'H:/epics-devel/base-7.0.2/src/template/ext'
make[1]: Leaving directory 'H:/epics-devel/base-7.0.2/src'
make -C ./test install
make[1]: Entering directory 'H:/epics-devel/base-7.0.2/test'
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/test/tools'
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/test/tools/O.windows-x64-static-vs2017'
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/expandVars.pl -t ../../.. -a windows-x64-static-vs2017 ../Snippets.plt Snippets.t
make[3]: Leaving directory 'H:/epics-devel/base-7.0.2/test/tools/O.windows-x64-static-vs2017'
make[2]: Leaving directory 'H:/epics-devel/base-7.0.2/test/tools'
make[1]: Leaving directory 'H:/epics-devel/base-7.0.2/test'
make -C ./modules install
make[1]: Entering directory 'H:/epics-devel/base-7.0.2/modules'
make -C ./libcom install
make[2]: Entering directory 'H:/epics-devel/base-7.0.2/modules/libcom'
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/modules/libcom/configure'
make[4]: Entering directory 'H:/epics-devel/base-7.0.2/modules/libcom/configure/O.windows-x64-static-vs2017'
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/convertRelease.pl checkRelease
make[4]: Leaving directory 'H:/epics-devel/base-7.0.2/modules/libcom/configure/O.windows-x64-static-vs2017'
make[3]: Leaving directory 'H:/epics-devel/base-7.0.2/modules/libcom/configure'
make[3]: Entering directory 'H:/epics-devel/base-7.0.2/modules/libcom/src'
make[4]: Entering directory 'H:/epics-devel/base-7.0.2/modules/libcom/src/O.windows-x64-static-vs2017'
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/expandVars.pl -DEPICS_LIBCOM_MAJOR_VERSION="3" -DEPICS_LIBCOM_MINOR_VERSION="17" -DEPICS_LIBCOM_MAINTENANCE_VERSION="2" -DEPICS_LIBCOM_DEVELOPMENT_FLAG="0" -t H:/epics-devel/base-7.0.2 -a windows-x64-static-vs2017 -D INSTALL_BIN=H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017  ../libComVersionNum.h@ ../O.Common/libComVersionNum.h
perl -CSD ../../src/misc/makeEpicsVersion.pl -o epicsVersion.h   H:/epics-devel/base-7.0.2/configure/CONFIG_BASE_VERSION
Building epicsVersion.h from H:/epics-devel/base-7.0.2/configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.2
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m forceBadAllocException.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        forceBadAllocException.obj ../../src/osi/os/WIN32/forceBadAllocException.cpp
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m setThreadName.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        setThreadName.obj ../../src/osi/os/WIN32/setThreadName.cpp
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m epicsGetopt.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        epicsGetopt.obj ../../src/osi/os/WIN32/epicsGetopt.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_parser.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_parser.obj ../../src/yajl/yajl_parser.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_lex.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_lex.obj ../../src/yajl/yajl_lex.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_gen.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_gen.obj ../../src/yajl/yajl_gen.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_encode.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_encode.obj ../../src/yajl/yajl_encode.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_buf.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_buf.obj ../../src/yajl/yajl_buf.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl_alloc.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl_alloc.obj ../../src/yajl/yajl_alloc.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m yajl.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        yajl.obj ../../src/yajl/yajl.c
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m timerQueuePassive.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        timerQueuePassive.obj ../../src/timer/timerQueuePassive.cpp
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        timerQueueActiveMgr.obj ../../src/timer/timerQueueActiveMgr.cpp
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m timerQueueActive.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        timerQueueActive.obj ../../src/timer/timerQueueActive.cpp
perl -CSD H:/epics-devel/base-7.0.2/bin/windows-x64-static-vs2017/mkmf.pl  -m timerQueue.d -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include -IH:/epics-devel/base-7.0.2/include/compiler/msvc -IH:/epics-devel/base-7.0.2/include/os/WIN32 -IH:/epics-devel/base-7.0.2/include        timerQueue.obj ../../src/timer/timerQueue.cpp
Can you send the complete output you see when you run “make –sj clean” and “make” up until the first error?
Sent: Sunday, February 24, 2019 1:19 PM
Cc: [email protected]
Subject: Re: EPICS Base compile failure on Windows-x64
Well, gnumake 4.2.1 gives me the following error:
configure/RULES_TOP:2: /c/epics/base-7.0.2/configure/RULES_TOP: No such file or directory
-Carl
On Sun, Feb 24, 2019 at 6:42 AM Mark Rivers <[email protected]> wrote:
Hi Carl,
I have built base 7.0.2 on Windows 10 with Community Edition 2017. I use the version of gnumake 4.2.1 from the link on this page:
https://epics.anl.gov/base/win32.php
I suggest you try that version of make.
Sent from my iPhone
On Feb 24, 2019, at 2:56 AM, Carl Willis via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
When attempting to build Epics Base v7.0.2 on Windows 10 using make from msys2 (or other sources) and Visual Studio 2017 Community Edition, this type of error keeps appearing:
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251     -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING    -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I../../src/osi/compiler/msvc -I../../src/osi/compiler/default -I. -I../../src/osi/os/WIN32 -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/c/epics/base-7.0.2/include/compiler/msvc -I/c/epics/base-7.0.2/include/os/WIN32 -I/c/epics/base-7.0.2/include -I/c/epics/base-7.0.2/include/compiler/msvc -I/c/epics/base-7.0.2/include/os/WIN32 -I/c/epics/base-7.0.2/include        -c ../../src/osi/os/WIN32/epicsTempFile.cpp
epicsTempFile.cpp
c1xx: fatal error C1083: Cannot open source file: '../../src/osi/os/WIN32/epicsTempFile.cpp': No such file or directory
Following the error, I identify the compiler as follows:
C:\epics\base-7.0.2>cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.16.27027.1 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
My startup script has the following:
rem Set the environment for Microsoft Visual Studio
call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" x64
In other words, the startup script correctly identifies the compiler, but a needed file appears to be missing (??)
Can anyone identify my error or issue?
Thanks
Carl Willis
rem Set the PATH for EPICS builds
call C:\EPICS\setup_epics_path.bat
rem This file sets up for an EPICS windows-x64 build
set EPICS_HOST_ARCH=windows-x64-static-vs2017
rem Execute the Visual Studio batch file for 64-bit builds
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" amd64
C:\Perl64\bin;^
%PATH%
EPICS Base compile failure on Windows-x64 Carl Willis via Tech-talk
Re: EPICS Base compile failure on Windows-x64 Mark Rivers via Tech-talk
Re: EPICS Base compile failure on Windows-x64 Carl Willis via Tech-talk
Prev: Re: EPICS Base compile failure on Windows-x64 Carl Willis via Tech-talk
Next: Re: EPICS and VXI query Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Next: Re: EPICS Base compile failure on Windows-x64 Johnson, Andrew N. via Tech-talk
ANJ, 25 Feb 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
