1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: quadEM Positions XY
From: Luka Debenjak via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 26 Feb 2019 13:48:48 +0100 (CET)
Hello everyone,
This will be my first email to the Tech-Talk.
I am testing the Quad Electrometer AH501B with quadEM driver and would like to understand how the numbers for X and Y positions are calculated. According to the manual [1] the position is calculated as:
Position = Diff/Sum * PositionScale - PositionOffset.
But if I calculate the position manually from given Diff and Sum it does not match to what I get from the corresponding PV ($(P)$(R)Pos[X,Y]:MeanValue_RBV). Even in the example screenshot from the quadEM driver manual [2] the X and Y positions do not correspond to the calculation above, e.g. Position X: 2800.5 != -860.2/3181.4 * 12330.0 - 3606.7 = −6940.5.
I am either doing something wrong or is the formula for Position incomplete. I would like to understand this, because we would like to use this Quad Electrometer to measure the beam position, so we need to understand the meaning of the X and Y Positions and how they are calculated.
Best regards,
Luka Debenjak
[1] http://cars9.uchicago.edu/software/epics/quadEMDoc.html
[2] http://cars9.uchicago.edu/software/epics/quadEM.png
Re: quadEM Positions XY Mark Rivers via Tech-talk
Prev: Re: EPICS Base compile failure on Windows-x64 Johnson, Andrew N. via Tech-talk
Next: Re: Can I configure CA Gateway to ignore boardcast Smith, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Can I configure CA Gateway to ignore boardcast Smith, Martin via Tech-talk
Next: Re: quadEM Positions XY Mark Rivers via Tech-talk
ANJ, 26 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
