Hello, Mark,
thank you for your answers. Unfortunately it doesn't work that way either:
startup
drvAsynIPPortConfigure("MOXA_4", "172.24.192.29:4004", 0, 0, 0)
drvAsynKeithley648x("6485", "MOXA_4",0)
drvAsynKeithley648x::drvAsynKeithley6485 port MOXA_4 can't connect to asynCommon on Octet server 0 address 0.
asynSetTraceIOMask("MOXA_4", 0, 0x2)
asynSetTraceMask("MOXA_4", 0, 0x9)
dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=6485")
The driver is from https://github.com/dohnarms/epics-Keithley_648x
In the driver there seems to be a mismatch
/* Public interface forward references */
int drvAsynKeithley648x(const char* myport,const char* ioport, int ioaddr);
* Define public interface methods
int drvAsynKeithley648x(const char *type, const char *myport,
const char *ioport, int ioaddr)
int status = asynSuccess;
Port* pport;
// int i;
asynStandardInterfaces *pInterfaces;
char inpBuf[BUFFER_SIZE];
int eomReason;
pport = (Port*)callocMustSucceed(1,sizeof(Port),"drvAsynKeithley6485”);
* Register public methods
/* Initialization method definitions */
static const iocshArg arg0 = {"type",iocshArgString};
static const iocshArg arg1 = {"myport",iocshArgString};
static const iocshArg arg2 = {"ioport",iocshArgString};
static const iocshArg arg3 = {"ioaddr",iocshArgInt};
static const iocshArg* args[]= {&arg0,&arg1,&arg2,&arg3};
static const iocshFuncDef drvAsynKeithley648xFuncDef =
{"drvAsynKeithley648x",4,args};
static void drvAsynKeithley648xCallFunc(const iocshArgBuf* args)
drvAsynKeithley648x(args[0].sval,args[1].sval,args[2].sval,args[3].ival);
/* Registration method */
static void drvAsynKeithley648xRegister(void)
static int firstTime = 1;
if( firstTime )
firstTime = 0;
iocshRegister( &drvAsynKeithley648xFuncDef,drvAsynKeithley648xCallFunc );
epicsExportRegistrar( drvAsynKeithley648xRegister );
That is why I have given four arguments in the st.cmd.
Danke,
Heinz
> On 6. Mar 2019, at 13:51, Mark Rivers <[email protected]> wrote:
> My comments are:
> Your original message says that drvAsynKeithley6845 take 3 arguments. Your actual commands call drvAsynKeithey648x with 4 arguments. Why the difference? Does 648x take an initial argument with the exact model number, or is that the name of the new port?
> I don't see the need for the asynOctetConnect line.
> Maybe this will work:
> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, "6845")
> I deleted the asynOctetConnect, deleted the 3 argument to drvKeithley648x, and changed the port passed in dbLoadRecords.
> Is this driver code on Github or somewhere else we can look at it?
> Mark
smime.p7s
Description: S/MIME cryptographic signature
- Re: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
- epics-Keithley_648x, drvAsynKeithley648x Heinz Junkes via Tech-talk
<2019>
2025
<2019>
2025
