1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: ADpython issues with openCV
From: "sandeep-kumar.malu--- via Tech-talk" <[email protected]>
Date: Tue, 26 Mar 2019 12:16:27 +0000
Hi
I created an IOC using the build instruction http://controls.diamond.ac.uk/downloads/support/adPython/0-1/documentation/doxygen/build_instructions_example.html.
On using numpy in adPythonTemplate.py , it works but same didn’t work with openCV (“Array processed” debug message in console). Also I am not able to run any of the openCV functions inside adPythonTemplate.py.   My st.cmd looks something like this
# Prosilica driver
prosilicaConfig("$(PREFIX)CAM", $(CAMID), 50, 0)
dbLoadRecords("ADBase.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
#adPythonPlugin
adPythonPluginConfigure("$(PREFIX)CONTOUR", "/home/malu/adPython_sample/adPythonTemplate.py", "Template", 16, 0, "$(PREFIX)CAM", 0, 50, 0,0,2097152)
dbLoadRecords("NDPluginBase.template","P=$(PREFIX),R=Contour1:, PORT=$(PREFIX)CONTOUR,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)CAM,NDARRAY_ADDR=0")
dbLoadRecords("$(ADPYTHON)/db/adPythonPlugin.template","P=$(PREFIX),R=Contour1:, PORT=$(PREFIX)CONTOUR, TIMEOUT=1,NDARRAY_PORT=$(PREFIX)CAM")
I am using following configurations
Areadetector - R3-2
ADpython – 1-4
Python-opencv-headless – 3.4.0
Opencv(build from source) – 3.4.0
Ubuntu – 18
Look forward to hear from you at an early date.
Many thanks
Sandeep Malu
Prev: Re: Cannot access to pilatusDoc Mark Rivers via Tech-talk
Next: Re: pvget is timing out Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Next: RE: ADpython issues with openCV tom.cobb--- via Tech-talk
ANJ, 01 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
