1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Build problem
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: peiyu Quan <[email protected]>
Date: Sun, 31 Mar 2019 05:23:44 +0000
Hi Peiyu,
Thank-you for posting the full build messages, they made it easy for me to see that you are trying to install EPICS Base in a directory that has spaces in its path. This will not work, our build system cannot handle spaces in directory names. You will need to rename your directory “Experimental Physics and Industrial Control System” replacing the spaces with some other character or just removing them. This is true for any EPICS-related software, you cannot not use spaces in any directory names above where the software is installed.
- Andrew
Sent from my iPad
On Mar 30, 2019, at 11:20 PM, peiyu Quan via Tech-talk <[email protected]> wrote:
Dear
    I just start to study epics. I am installing EPICS 7.0 base in windows 10 system.
According to guide, Set EPICS_HOST_ARCH in startup directory:
    set
Then in base directory:
gmake clean uninstall
gmake
The result show some "error 2". I don't know what mean it is. Whether I have success in installing it?
Please see red words.
Thank you very much
Peiyu
The result as following:
C:/Strawberry/c/bin/gmake -C ./configure install
gmake[1]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
C:/Strawberry/c/bin/gmake -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
gmake[2]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/configure/O.windows-x64'
gmake[2]: Nothing to be done for 'install'.
gmake[2]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/configure/O.windows-x64'
gmake[1]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/configure'
C:/Strawberry/c/bin/gmake -C ./src install
gmake[1]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src'
C:/Strawberry/c/bin/gmake -C ./tools install
gmake[2]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64 ../../..
C:/Strawberry/c/bin/gmake -C O.windows-x64 -f ../Makefile TOP=../../.. \
gmake[3]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/tools/O.windows-x64'
gmake[3]: Nothing to be done for 'install'.
gmake[3]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/tools/O.windows-x64'
gmake[2]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/tools'
C:/Strawberry/c/bin/gmake -C template/base install
gmake[2]: Entering directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/template/base'
perl -CSD C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../../..
Can't open perl script "C:/Users/peiyu/Desktop/epics_software/Experimental": No such file or directory
gmake[2]: *** [../../../configure/RULES_ARCHS:67: O.windows-x64] Error 2
gmake[2]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src/template/base'
gmake[1]: *** [../configure/RULES_DIRS:84: template/base.install] Error 2
gmake[1]: Leaving directory 'C:/Users/peiyu/Desktop/epics_software/Experimental Physics and Industrial Control System/Base/base-7.0.2.1/src'
gmake: *** [configure/RULES_DIRS:84: src.install] Error 2
Tech-talk Digest, Vol 13, Issue 150 peiyu Quan via Tech-talk
Prev: Tech-talk Digest, Vol 13, Issue 150 peiyu Quan via Tech-talk
Next: Re: dbdlint (dbd/db verify tool) Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Next: EPICS Controls Engineering Job Opportunity - Full-Time, Direct Role Alexander Gorinsky via Tech-talk
ANJ, 01 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
