1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: PvData , PvAccess, Confusion with different hardware architectures
From: Heinz Junkes via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 2 Apr 2019 17:12:23 +0200
Hi folks,
I am running a PvData client on RTEMS on a MVME6100 (PPC) and I see a behaviour that I can't even classify:
PV-Server is a pythonIOC running on a linux - system. The PvStructure is this:
CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK structure
    string[] labels
    structure value
        double[] column0
        double[] column1
        double[] column2
        int[] column3
    long counter
    string descriptor
    structure timeStamp
        long secondsPastEpoch
        int nanoseconds
        int userTag
    structure alarm
        int severity
        int status
        string message
On the RTEMS-CPU the following code is used:
funktion put( long val ) // gets called put ([0…9])
PvaClientPutDataPtr putData = pvaClientPut->getData();
        PVLongPtr counterField = putData->getPVStructure()->getSubField<PVLong>("counter");
        cout << "counterField : " << counterField << "\n";
        //shared_vector<std::string> labels;
        PVStringArrayPtr labels = putData->getPVStructure()->getSubField<PVStringArray>("labels");
        PVStringArray::const_svector l(labels->view());
        //cout << "labels : "<< labels->view() << "\n";
        //for(unsigned int i = 0; i < labels->getCapacity(); i++ ) {
        //  cout << "label index " << i << " : " << l[i] << "\n";
        shared_vector<double> newX(100);
          //PVIntArray::svector newTimeIndex;
        for(int i=0; i < 100; i++) newX[i] = 0 + i;
        shared_vector<const double> x(freeze(newX));
        shared_vector<double> newY(100);
        for(int i=0; i < 100; i++) newY[i] = 1 + i;
        shared_vector<const double> y(freeze(newY));
        shared_vector<double> newZ(100);
        for(int i=0; i < 100; i++) newZ[i] = 2 + i;
        shared_vector<const double> z(freeze(newZ));
        shared_vector<int32> newTimeIndex(100);
        for(int i=0; i < 100; i++) newTimeIndex[i] = 3 + i;
        shared_vector<const int32> data(freeze(newTimeIndex));
       //PVStructurePtr pvValue = putData->getPVStructure();
       // pvValue->dumpValue(cout);
        PVStructurePtr pvStructure = putData->getPVStructure()->getSubField<PVStructure>("value");
        if(!pvStructure) {
            cout << "value is not a structure\n";
            return;
        PVFieldPtrArray pvFields = pvStructure->getPVFields();
        for(size_t ind = 0; ind < pvFields.size() ; ++ind)
          PVFieldPtr pvField = pvFields[ind];
          cout << "starting field " << pvField->getFieldName() << " ... " << l[ind] << "\n";
          cout << "type " << pvField->getField()->getType() << "\n";
          if(pvField->getField()->getType()!=scalarArray) {
            cout << "fields is not a scalar array\n";
            continue;
          PVScalarArrayPtr pvScalarArray = static_pointer_cast<PVScalarArray>(pvField);
          pvScalarArray->setLength(100);
          switch (ind) {
            case 0: pvScalarArray->putFrom(x); cout << " put x \n"; break;
            case 1: pvScalarArray->putFrom(y); cout << " put y \n"; break;
            case 2: pvScalarArray->putFrom(z); cout << " put z \n"; break;
            case 3: pvScalarArray->putFrom(data); cout << " put data \n"; break;
        counterField->put(val);
        pvaClientPut->issuePut();
On the RTEMS CPU it self I read:
PvaClientPut::checkConnectState channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
counterField : 0
starting field column0 ... x
type scalarArray
 put x
starting field column1 ... y
type scalarArray
 put y
starting field column2 ... z
type scalarArray
 put z
starting field column3 ... time_index
type scalarArray
 put data
PvaClientPut::issuePut channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK pvStructure
structure
    string[] labels ["x", "y", "z", "time_index"]
    structure value
        double[] column0 [0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99]
        double[] column1 [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100]
        double[] column2 [2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101]
        int[] column3 [3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102]
    long counter 1
    string descriptor
    structure timeStamp
        long secondsPastEpoch 0
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
 bitSet {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16}
PvaClientPut::putDone channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status.isOK true
putDone CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK status Status [type=OK]
 counter : 2
PvaClientPut::getData channelName CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
counterField : 1
type scalarArray
 put x
type scalarArray
 put y
type scalarArray
 put z
type scalarArray
 put data
structure
    structure value
    long counter 2
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
On a Darwin - host with
pvmonitor -r "" CRYVISIL:STM:FASTSCAN:IMAGE_CHUNK
I read:
    structure value
        double[] column0 [0,8,16,24,32,40,48,56,64,72,80,88,96,0,0,2.122e-314,5,13,21,29,37,45,53,61,69,77,85,93,3.49671e-307,6,14,22,30,38,46,54,62,70,78,86,94,3.49671e-307,7,15,23,31,39,47,55,63,71,79,87,95,3.49671e-307,2.75859e-313,6.15379e-313,9.54898e-313,1.29442e-312,1.63394e-312,1.97346e-312,6.2132e-311,2.14309e-314,0,0,2.122e-314,2,10,18,26,34,42,50,58,66,74,82,90,98,6,14,22,30,38,46,54,62,70,78,86,94,2.02073e-321,3.60739e-313,7.00259e-313,1.03978e-312,1.3793e-312,1.71882e-312,2.05834e-312,2.43117e-315,0]
        double[] column1 [1,9,17,25,33,41,49,57,65,73,81,89,97,5,13,21,29,37,45,53,61,69,77,85,93,101,3.18299e-313,6.57819e-313,9.97338e-313,1.33686e-312,1.67638e-312,2.0159e-312,2.09612e-296,5.26795e-304,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column2 [2,10,18,26,34,42,50,58,66,74,82,90,98,1.9098e-313,5.30499e-313,8.70018e-313,1.20954e-312,1.54906e-312,1.88858e-312,5.26795e-304,3.05017e+06,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        int[] column3 [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83,87,91,95,99,0,42691016,42691272,16195288,1414742849,1258291200,16195288,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
    long counter 1
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
    structure value
        double[] column0 [0,8,16,24,32,40,48,56,64,72,80,88,96,1,9,17,25,33,41,49,57,65,73,81,89,97,2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column1 [1,9,17,25,33,41,49,57,65,73,81,89,97,2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        double[] column2 [2,10,18,26,34,42,50,58,66,74,82,90,98,6.36599e-314,4.03179e-313,7.42699e-313,1.08222e-312,1.42174e-312,1.76126e-312,2.10078e-312,5.09279e-313,1.86736e-312,0,0,9.16401e-72,5,13,21,29,37,45,53,61,69,77,85,93,1.71457e-311,9,17,25,33,41,49,57,65,73,81,89,97,1.4854e-313,4.88059e-313,8.27578e-313,1.1671e-312,1.50662e-312,1.84614e-312,4.29492e-311,1.6458e+98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        int[] column3 [3,7,11,15,19,23,27,31,35,39,43,47,51,55,59,63,67,71,75,79,83,87,91,95,99,2904,1,42698272,24,0,5205556,1095189855,88,0,0,0,0,0,0,0,0,0,2,0,825241856,0,42693840,1074266112,1075052544,1075576832,1075970048,1076232192,1076494336,1076756480,1076953088,1077084160,1077215232,1077346304,1077477376,1077608448,1077739520,1077870592,1077968896,1078034432,1078099968,1078165504,1078231040,1078296576,1078362112,1078427648,1078493184,1078558720,1078624256,1078689792,1078755328,1078820864,1078886400,1078951936,1079001088,1079033856,1079066624,1079099392,1079132160,1079164928,1079197696,1079230464,1079263232,1079296000,1079328768,1079361536,1079394304,1079427072,1079459840,1079492608,1079525376,1079558144,808,1074266112,1075052544,1075576832]
    long counter 2
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
Only every 4th element is included in the  int array (ind == 3) and every 8th element in the double arrays (ind == 0-2)?
If I run the client code on the Darwin host, everything looks fine. All 100 elements are taken over in the arrays on the server.
    structure value
    long counter 9
    string descriptor
    structure timeStamp
        int nanoseconds 0
        int userTag 0
    structure alarm
        int severity 0
        int status 0
        string message
Does anyone have any idea what's happening?
I guess of course something with type-len (int ==4, double ==8).
Danke, Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
Prev: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Tech-talk
Next: Re: EPICS Base 3.15 release notes epicsVersion.h macro snippet issues J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Next: Re: PvData , PvAccess, Confusion with different hardware architectures Michael Davidsaver via Tech-talk
ANJ, 02 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
