Hi Enrique,
Sorry I forgot to CC tech-talk on my reply yesterday, but the complete thread is below.
I don’t understand why asyn is able to receive the udp messages when tcp is disabled, but not if it is enabled. Perhaps someone else has an idea?
Do you actually need to send udp messages on port 10001? If not, then you might try changing this line:
drvAsynIPPortConfigure("test-mps-ctbox-n0001_udp","test-mps-ctbox-n0001:10001:20001 udp",
0, 0, 1)
to this, i.e. configure to send on 20001 as well, but don’t actually send anything.
drvAsynIPPortConfigure("test-mps-ctbox-n0001_udp","test-mps-ctbox-n0001:20001:20001 udp",
0, 0, 1)
I don’t think that will make a difference, but if there is a bug in our driver it might.
Also if you send me your driver code, or a link to Github if it is there, I will be happy to see if I can spot a problem.
Sent: Wednesday, April 17, 2019 9:54 AM
To: Mark Rivers <[email protected]>
Subject: RE: Current transducer Box asynPortDriver using tcp and udp timing out
Hi Mark,
Thanks for your quick reply.
The output for asynReport 10 test-mps-ctbox-n0001_udp is as follows:
test-mps-ctbox-n0001_udp multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0xff traceIOMask:0xb traceInfoMask:0xff
interposeInterfaceList
asynOctet pinterface 0x7effaa877240 drvPvt 0x55c9fa45cc90
interfaceList
asynCommon pinterface 0x7effaa8747b0 drvPvt 0x55c9fa45bdc0
asynOption pinterface 0x7effaa8747d0 drvPvt 0x55c9fa45bdc0
asynOctet pinterface 0x55c9fa45bee0 drvPvt 0x55c9fa45bdc0
Port test-mps-ctbox-n0001:10001:20001 udp: Connected
fd: 5
Characters written: 80
Characters read: 0
I do not see anything wrong on the
asynReport command output
And my IOC is listening on that udp port,
L
bernalru@bernalru:~$ sudo netstat -tulpn | grep 20001
udp 0 0 0.0.0.0:20001 0.0.0.0:* 10439/../../bin/lin
bernalru@bernalru:~$ top –H –u bernalru
10439 bernalru 20 0 620004 8652 6420 S 0.0 0.8 0:00.07 st.cmd
If I disable all tcp communications and only enable udp com, I can see all the streamed data that comes from the box.
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1782] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort locking
port
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1820] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort taking
mutex 0x7f44b4001090
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1822] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort queueing
request
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1565] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp addr -1 queueRequest priority
0 not lockHolder
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1576] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp schedule queueRequest timeout
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1835] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort waiting
for event
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:886] [test-mps-ctbox-n0001_udp,0x5632e8758db0,50] asynManager::portThread port=test-mps-ctbox-n0001_udp
callback
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:940] [test-mps-ctbox-n0001_udp,0x5632e8758db0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
signaling begin event
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:945] [test-mps-ctbox-n0001_udp,0x5632e8758db0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
waiting for mutex from queueUnlockPort
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1846] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort got
event from callback
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:686] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001:10001:20001 udp read.
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:748] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001:10001:20001 udp (from 10.41.218.251:10001)
read 1440
}1
}1\a\000i\204\032:~1\a\000\017\024\3759\1771\a\000\243\3425:\2001\a\000\251\351\022:\2011\a\000\016\2037:\2021\a\000\245\0052:\2031\a\000y\365\v:\2041\a\000\224\245.:\2051\a\000\017D\034:\2061\a\000R.(:
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/interfaces/asynOctetSyncIO.c:224] [asyndvrctboxTask,0x5632e875be00,50] asynOctetSyncIO read:
}1
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1867] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp queueUnlockPort
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1898] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueUnlockPort waiting
for event
2019/04/17 10:35:01.678 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1901] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp queueUnlockPort unlock mutex 0x7f44b4001090
complete.
port
request
0 not lockHolder
for event
callback
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:940] [test-mps-ctbox-n0001_udp,0x5632e8758db0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:945] [test-mps-ctbox-n0001_udp,0x5632e8758db0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1846] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort got
event from callback
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:556] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001:10001:20001 udp write.
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:558] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001:10001:20001 udp write 80
\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000\000
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:666] [asyndvrctboxTask,0x5632e875be00,50] wrote 80 to test-mps-ctbox-n0001:10001:20001 udp, return
asynSuccess.
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/interfaces/asynOctetSyncIO.c:198] [asyndvrctboxTask,0x5632e875be00,50] asynOctetSyncIO wrote:
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1867] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp queueUnlockPort
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1898] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp asynManager::queueUnlockPort waiting
for event
2019/04/17 10:35:01.679 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1901] [asyndvrctboxTask,0x5632e875be00,50] test-mps-ctbox-n0001_udp queueUnlockPort unlock mutex 0x7f44b4001090
complete.
And
asynOctet pinterface 0x7f44cfb9f240 drvPvt 0x5632e875a030
interfaceList
asynCommon pinterface 0x7f44cfb9c7b0 drvPvt 0x5632e8756870
asynOption pinterface 0x7f44cfb9c7d0 drvPvt 0x5632e8756870
asynOctet pinterface 0x5632e8756990 drvPvt 0x5632e8756870
fd: 4
Characters written: 3280
Characters read: 59040
udp 214272 0 0.0.0.0:20001 0.0.0.0:* 11283/../../bin/lin
11283 bernalru 20 0 615204 7924 6364 S 0.0 0.8 0:00.02 st.cmd
Any idea on how can I debug my application or anywhere I can have a look on asyn code?
Thanks for the help Mark.
Enrique
Sent: Tuesday, April 16, 2019 7:50 PM
To: Bernal Ruiz, Enrique <[email protected]>
Hi Enrique,
It seems that what you are trying to do should work.
I am not sure anyone has used drvAsynIPPort to read UDP non-broadcast UDP messages, but perhaps they have.
I know for sure that it works for reading UDP broadcast messages, because I recently tested it and posted results in this tech-talk message:
https://epics.anl.gov/tech-talk/2019/msg00515.php
It seems that poll() is timing out on that fd.
Can you send the output of the following iocsh command that will show information about the asyn driver:
Also send the output of this command which will show if the system sees that process listening for udp messages on port 20001.
I am working on an asynPortDriver for a Current Transducer box (CAENels) that uses tcp for configuration and monitoring purposes and udp for streaming data.
Using epics-base 3.15.6 and asyn 4.34 on a debian stretch machine.
I have a test IOC that calls drvAsynIPPortConfigure twice, as follows:
drvAsynIPPortConfigure("test-mps-ctbox-n0001", "test-mps-ctbox-n0001:10001 tcp", 0, 0, 0)
drvAsynIPPortConfigure("test-mps-ctbox-n0001_udp","test-mps-ctbox-n0001:10001:20001 udp", 0, 0, 1)
The tcp port uses remotePort=10001 and noProccessEos=0, and the udp port uses remotePort=10001, localPort 20001 and noProccessEos=1.
The driver is configured as follows:
ASYN_CANBLOCK and AUTO_CONNECT.
It uses two asynUsers, one for tcp communication and one for udp communication,
creates necessary asyn interfaces for tcp-based configuration and monitoring commands that call pasynOctetSyncIO->writeRead(), and are driven by passive PVs or periodic scan PVs processed every 10Hz.
and creates an epicsThread, to acquire the data streamed by the CT-Box, that calls pasynOctetSyncIO->read() at least twice a second (user configurable) to read blocks of 180 U64 words. A call to pasynOctetSyncIO->write() has been included
in the thread after the read for testing purposes.
The issue is that the pasynOctetSyncIO->writeReads (using tcp) and pasynOctetSyncIO->writes(using udp) work fine most of the time, I can see all sent and received data using Wireshark, but pasynOctetSyncIO->reads(using udp) always timeout.
The data is sent by the CT-Box (observed with Wireshark).
This is the observed behavior ~90% of the time. Using a TIMEOUT=2 seconds.
This is the IOC output for one tcp call made by a PV named FPSALARM:OUTST followed by two udp calls made by the epicsThread trying to read 1440 bytes and writing 80 bytes.
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1782] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueLockPort locking port
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1820] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueLockPort taking mutex 0x7f73dc000a10
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1822] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueLockPort queueing request
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1565] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 addr -1 queueRequest priority 0 not lockHolder
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1576] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 schedule queueRequest timeout
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:886] [test-mps-ctbox-n0001,0x55d4fbfccd30,50] asynManager::portThread port=test-mps-ctbox-n0001 callback
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:940] [test-mps-ctbox-n0001,0x55d4fbfccd30,50] test-mps-ctbox-n0001 asynManager::queueLockPortCallback signaling begin
event
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:945] [test-mps-ctbox-n0001,0x55d4fbfccd30,50] test-mps-ctbox-n0001 asynManager::queueLockPortCallback waiting for
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1835] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueLockPort waiting for event
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1846] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueLockPort got event from callback
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/miscellaneous/asynInterposeEos.c:263] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 flush
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:807] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001:10001 tcp flush
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:556] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001:10001 tcp write.
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:558] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001:10001 tcp write 17
FPSALARM:OUTST:?
FPSALARM:OUTST:?\r
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:666] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] wrote 17 to test-mps-ctbox-n0001:10001 tcp, return asynSuccess.
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/miscellaneous/asynInterposeEos.c:178] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 wrote
FPSALARM:OUTST:?
FPSALARM:OUTST:?\r
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/interfaces/asynOctetSyncIO.c:262] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] asynOctetSyncIO wrote:
FPSALARM:OUTST:?
FPSALARM:OUTST:?
2019/04/16 17:00:00.750 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:686] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001:10001 tcp read.
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:756] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001:10001 tcp read 4
OK
OK\r\n
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/miscellaneous/asynInterposeEos.c:235] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 read 4 bytes eom=0
OK
OK\r\n
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/interfaces/asynOctetSyncIO.c:270] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] asynOctetSyncIO read:
OK
OK
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1867] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 queueUnlockPort
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1898] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 asynManager::queueUnlockPort waiting for event
2019/04/16 17:00:00.760 [test-mps-ctbox-n0001,-1,0] [../../asyn/asynDriver/asynManager.c:1901] [TEST_MPS:CTBOX_N0001,0x55d4fbfd1140,50] test-mps-ctbox-n0001 queueUnlockPort unlock mutex 0x7f73dc000a10 complete.
2019/04/16 17:00:01.212 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1782] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort locking port
2019/04/16 17:00:01.212 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1820] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort taking mutex 0x7f73d0000fa0
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1822] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort queueing request
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1565] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp addr -1 queueRequest priority 0 not lockHolder
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1576] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp schedule queueRequest timeout
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:886] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] asynManager::portThread port=test-mps-ctbox-n0001_udp callback
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:940] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:945] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/16 17:00:01.213 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1835] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort waiting for event
2019/04/16 17:00:01.214 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1846] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort got event from
callback
2019/04/16 17:00:01.214 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:686] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001:10001:20001 udp read.
2019/04/16 17:00:03.215 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1867] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp queueUnlockPort
2019/04/16 17:00:03.215 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1898] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueUnlockPort waiting for
event
2019/04/16 17:00:03.216 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1901] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp queueUnlockPort unlock mutex 0x7f73d0000fa0
complete.
sevr=info 2019-04-16 17:00:03.216 asyndvrctboxTask[140135778531072]: *** TEST_MPS:CTBOX_N0001:[dataAcquisitionTask] error calling read, status=1, error=test-mps-ctbox-n0001:10001:20001 udp timeout: Resource
temporarily unavailable ***
2019/04/16 17:00:03.217 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1782] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort locking port
2019/04/16 17:00:03.217 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1820] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort taking mutex 0x7f73d0000fa0
2019/04/16 17:00:03.218 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1822] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort queueing request
2019/04/16 17:00:03.218 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1565] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp addr -1 queueRequest priority 0 not lockHolder
2019/04/16 17:00:03.218 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1576] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp schedule queueRequest timeout
2019/04/16 17:00:03.219 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:886] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] asynManager::portThread port=test-mps-ctbox-n0001_udp callback
2019/04/16 17:00:03.219 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:940] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/16 17:00:03.219 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:945] [test-mps-ctbox-n0001_udp,0x55d4fbfcf460,50] test-mps-ctbox-n0001_udp asynManager::queueLockPortCallback
2019/04/16 17:00:03.219 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1835] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort waiting for event
2019/04/16 17:00:03.220 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1846] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueLockPort got event from
callback
2019/04/16 17:00:03.220 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:556] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001:10001:20001 udp write.
2019/04/16 17:00:03.221 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:558] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001:10001:20001 udp write 80
2019/04/16 17:00:03.227 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/drvAsynSerial/drvAsynIPPort.c:666] [asyndvrctboxTask,0x55d4fbfd19a0,50] wrote 80 to test-mps-ctbox-n0001:10001:20001 udp, return asynSuccess.
2019/04/16 17:00:03.228 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/interfaces/asynOctetSyncIO.c:198] [asyndvrctboxTask,0x55d4fbfd19a0,50] asynOctetSyncIO wrote:
2019/04/16 17:00:03.234 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1867] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp queueUnlockPort
2019/04/16 17:00:03.234 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1898] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp asynManager::queueUnlockPort waiting for
event
2019/04/16 17:00:03.235 [test-mps-ctbox-n0001_udp,-1,0] [../../asyn/asynDriver/asynManager.c:1901] [asyndvrctboxTask,0x55d4fbfd19a0,50] test-mps-ctbox-n0001_udp queueUnlockPort unlock mutex 0x7f73d0000fa0
complete.
Strace shows that the poll() call, in readIt() function (drvAsynIPPort.c line 714) timeout
poll([{fd=5, events=POLLIN}], 1, 2000) = 0 (Timeout)
recvfrom(5, 0x7f73d0000920, 1440, 0, 0x7f73e74cab90, [16]) = -1 EAGAIN (Resource temporarily unavailable)
While the call to writeIt succeeds.
poll([{fd=5, events=POLLOUT}], 1, 2000) = 1 ([{fd=5, revents=POLLOUT}])
sendto(5, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 80, 0, {sa_family=AF_INET, sin_port=htons(10001), sin_addr=inet_addr("10.41.218.251")}, 16) = 8
The other ~10%, tcp calls timeout and udp read and writes succeed (not very common).
My question is, is my approach correct? If not which would be the appropriate approach to implement an asynPortDriver for a device that uses tcp and udp over the same remote port.
Enrique
Enrique Bernal Ruiz
Controls Engineer II
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Email: [email protected]
