1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: GPIB replies lost?
From: Benjamin Franksen via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 26 Apr 2019 17:13:21 +0200
Am 23.04.19 um 21:25 schrieb Michael Davidsaver via Tech-talk:
> On 4/19/19 1:06 PM, Michael Davidsaver wrote:
>> All,
>> I've come across a new (to me) oddity involving GPIB communication between
>> a Keysight/Agilent E5810A GPIB to ethernet bridge, and a Keysight/Agilent/HP
>> 3458A DMM.  I'm contacting Keysight support, but thought I'd see if someone
>> had already run across this issue.
> In the end the answer turns out to be "END".  To quote the 3458A manual.
>> The END command enables or disables the GPIB End Or Identify (EOI) function.
>> OFF  0  EOI line never set true
>> Power-on control = OFF.
> Not an intuitive default to me.
> So "END;ID?", or giving a '\n' terminator to the vxi11 device_read() call, works.
> (I must admit it was news to me that termChar is a vxi11 protocol feature)
> It also seems that the E5810A does not return partial output on timeout.
> It's EOI, termChar, or an error.
They now ship the E5810B (note the last letter). When I first had this
thing on my desk it immediately froze up and failed to further respond
to anything if the first message you sent was a "*IDN?". Which, I think,
is not an unusual first command to send to a new device. It needed a
hard reset (uncoupling the mains) to recover from that. Perhaps they
fixed that particular bug in the meantime. I was also quite disappointed
about the external power supply connected to the box via a wobbly
consumer grade connector. Not something I like to put in a production
system. All in all clearly inferior compared to the previous "A"
version. It is a shame what became of the once renowned brand
"Hewlett-Packard" (first renamed to "Agilent", then "Keysight", and it
looks as if product quality deteriorated along with the brand name). I
recommend you hold on to your E5810As for those older devices which
require GPIB; and where possible switch to devices that are controlled
directly via ethernet.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
GPIB replies lost? Michael Davidsaver via Tech-talk
Re: GPIB replies lost? Michael Davidsaver via Tech-talk
Prev: Re: [SNL] possibility to cut the argument string. Benjamin Franksen via Tech-talk
Next: gen_iocsh_reg.pl Benjamin Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: GPIB replies lost? Michael Davidsaver via Tech-talk
Next: Question about XY graph of CSS suntianxiao via Tech-talk
ANJ, 26 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
