I recently wrote this little perl script (attached) to automate the writing of iocsh registration code using a trivial but (I think) complete declarative specification "language" that is easy to compose on the command line or in a Makefile. I am posting the code and an example of what it does in the hope that it may turn out to be useful for others. Here is the help output (slightly re-formatted for this email): """ > gen_iocsh_reg.pl -h Usage: gen_iocsh_reg.pl [REG=<registrar>] <command>=[<args>] ... where <registrar> is the name of a C function to register the commands (if not specified you'll have to call iocshRegister yourself for each command) <command> is the name of a command (in C as well as in the shell) <args> is a comma separated list of argument descriptions <arg> <arg> describes an argument to the underlying C command and is either * a constant literal value (for instance 0 or "a string"), or * an iocsh argument description of the form <name>:<type> (for instance card_number:Int) where <type> is one of {Int, Double, String}. Only arguments of the <name>:<type> sort are exposed as arguments to the command in the shell. """ Here is a real-world example use case,. This is from a Makefile in one of our projects: """ iocshExtra.c: $(PERL) $(BII_SCRIPTS_BIN)/gen_iocsh_reg.pl REG=registerIocshExtra\ asDump=0,0,verbosity:Int \ bootShow= bootChange= \ gevShow= gevDelete=name:String gevUpdate=name:String,value:String > $@ """ From this it generates the following boilerplate code: """ /* * IOC shell command registration */ #include "epicsExport.h" #include "iocsh.h" static const iocshArg asDumpArg0 = { "verbosity", iocshArgInt }; static const iocshArg *const asDumpArgs[] = { &asDumpArg0 }; static const iocshFuncDef asDumpDef = {"asDump", 1, asDumpArgs}; static void asDumpWrapper(const iocshArgBuf *args) { asDump(0, 0, args[0].ival); } static const iocshArg *const bootChangeArgs[] = {}; static const iocshFuncDef bootChangeDef = {"bootChange", 0, bootChangeArgs}; static void bootChangeWrapper(const iocshArgBuf *args) { bootChange(); } static const iocshArg *const bootShowArgs[] = {}; static const iocshFuncDef bootShowDef = {"bootShow", 0, bootShowArgs}; static void bootShowWrapper(const iocshArgBuf *args) { bootShow(); } static const iocshArg gevDeleteArg0 = { "name", iocshArgString }; static const iocshArg *const gevDeleteArgs[] = { &gevDeleteArg0 }; static const iocshFuncDef gevDeleteDef = {"gevDelete", 1, gevDeleteArgs}; static void gevDeleteWrapper(const iocshArgBuf *args) { gevDelete(args[0].sval); } static const iocshArg *const gevShowArgs[] = {}; static const iocshFuncDef gevShowDef = {"gevShow", 0, gevShowArgs}; static void gevShowWrapper(const iocshArgBuf *args) { gevShow(); } static const iocshArg gevUpdateArg0 = { "name", iocshArgString }; static const iocshArg gevUpdateArg1 = { "value", iocshArgString }; static const iocshArg *const gevUpdateArgs[] = { &gevUpdateArg0, &gevUpdateArg1 }; static const iocshFuncDef gevUpdateDef = {"gevUpdate", 2, gevUpdateArgs}; static void gevUpdateWrapper(const iocshArgBuf *args) { gevUpdate(args[0].sval, args[1].sval); } static void registerIocshExtra(void) { static int firstTime = 1; if (firstTime) { firstTime = 0; iocshRegister(&asDumpDef, asDumpWrapper); iocshRegister(&bootChangeDef, bootChangeWrapper); iocshRegister(&bootShowDef, bootShowWrapper); iocshRegister(&gevDeleteDef, gevDeleteWrapper); iocshRegister(&gevShowDef, gevShowWrapper); iocshRegister(&gevUpdateDef, gevUpdateWrapper); } } epicsExportRegistrar(registerIocshExtra); """ Cheers Ben Attachment:
gen_iocsh_reg.pl Attachment:
signature.asc
ANJ, 29 Apr 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
