1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pmac driver bug
From: "giles.knap--- via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Davis, Mark" <[email protected]>
Date: Fri, 31 May 2019 07:42:52 +0000
Mark,
Can you let me know in which version you saw REMOVE_LIMITS_ON_HOME commented out?
In my history, it has always been defined since it was copied into this project in Mar 2016.
Sent: 30 May 2019 15:09:44
To: Knap, Giles (DLSLtd,RAL,LSCI); [email protected]
One correction:  The macro that was commented out in the older version
is REMOVE_LIMITS_ON_HOME, NOT PMAC_CID_POWER  (which is a const).
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 5/30/2019 3:47 AM, [email protected] wrote:
> Thanks, Mark,
> I will roll a fix into the next release.
> ________________________________
> From: Davis, Mark <[email protected]>
> Sent: 29 May 2019 19:04:39
> To: [email protected]; Knap, Giles (DLSLtd,RAL,LSCI)
> Subject: pmac driver bug
> To Giles and other interested parties,
> I found another bug in the pmac driver (version 2-4-10):
> The section of code in the pmacAxis::home() function that is
> conditionally compiled based on the macro REMOVE_LIMITS_ON_HOME does not
> check for the PMAC_CID_POWER CID value, so when using a Power Brick
> controller it simply logs an error (if enabled) and exits.
> The older version of the driver I was using had the definition of the
> PMAC_CID_POWER macro commented out, so the offending section of code was
> not included and it would just send the home command regardless of what
> type of controller you have.
> For now, I commented this macro out in the newer version to get the same
> behavior as the older one.
> Mark Davis
> NSCL/FRIB
> [email protected]
Re: pmac driver bug Davis, Mark via Tech-talk
Re: pmac driver bug giles.knap--- via Tech-talk
Prev: RE: [EXTERNAL] RE: How to share asyn's queue thread among ports? Mark Rivers via Tech-talk
Next: Re: pmac driver bug Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pmac driver bug Davis, Mark via Tech-talk
ANJ, 31 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
