1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: How to share asyn's queue thread among ports?
From: Klemen Vodopivec via Tech-talk <[email protected]>
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 3 Jun 2019 13:09:09 -0400
Hi Martin,
I understand your point and agree that 500 idling threads would generally not be a problem for Linux OS. It is our specific application that we can't afford a lot of context switching. It's a data acquisition software which includes detector communication, due to the fact we're using same physical connection. Data throughput peaks over 100MB/s or about 12 mio events/s. Software design is similar to AreaDetector but deals with event packets around 4k big - number of interrupts can get quite high to the point we're doing coalescing to minimize context switching. This is where it gets interesting. We're using asyn generic pointer interface for data as well as asynInt32 interface for detector params, with 500 detectors that means 500 plugins receiving 100MB/s. In theory all plugins receive the packets and they decide what they're interested in, but in practice we're filtering packet types and also disconnecting plugins when not needed. There's other CPU intensive data processing plugins that we can't afford to loose events.
I just through in a few figures but I can share ICALEPCS paper for more details. We've been running this way for several years now but we're looking for changes and are evaluating are options. Careful redesign with many number of threads for detector communication is one option.
-- Klemen
On 5/31/19 1:42 PM, Konrad, Martin wrote:
Hi Klemen,
The obvious solution is to use asyn's blocking mode, but there's up
to 500 ports resulting in as many threads.
Could you please elaborate on why you think this is a problem? It might
not look pretty but in practice CPU overhead might actually be small:
Asyn is using threads because it needs to wait for asynchronous
operations to complete. The pattern is generally: process some data
(which takes a very short time), go to sleep and wait for the next
event/interrupt. Whenever you send a thread to sleep the scheduler is
performing a context switch.
Let's say you have 1000 events/s to process with a single thread. You
wake up 1000 times/s and go to sleep 1000 times/s resulting in 1000
context switches/s. If you are processing the 1000 events with 1000
threads, each of them wakes up once per second and goes to sleep. Again
1000 context switches/s total.
I'm simplify here but CPU overhead might not be as bad as you might
think in the first place. Memory overhead of course is a different story.
-Martin
Re: How to share asyn's queue thread among ports? Konrad, Martin via Tech-talk
Prev: RE: Scanning 101 tom.cobb--- via Tech-talk
Next: Re: Receiving duplicate monitor values using CA PV Gateway Layne (US), William C via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to share asyn's queue thread among ports? Konrad, Martin via Tech-talk
Next: Job opportunity at ANL Shen, Guobao via Tech-talk
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
