1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Receiving duplicate monitor values using CA PV Gateway
From: "Layne \(US\), William C via Tech-talk" <[email protected]>
Date: Mon, 3 Jun 2019 17:13:13 +0000
Here is the output for a few seconds.
--------------------------------TERMINAL TO GATEWAY-----------------------------
[user@host ~]$ cainfo SYSP_HEARTBEAT && camonitor SYSP_HEARTBEAT
SYSP_HEARTBEAT
    State:            connected
    Host:             <direct_network>:37223
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
SYSP_HEARTBEAT                 2019-05-31 14:07:12.908878 16726
SYSP_HEARTBEAT                 2019-05-31 14:07:13.908874 16727
SYSP_HEARTBEAT                 2019-05-31 14:07:14.908876 16728
SYSP_HEARTBEAT                 2019-05-31 14:07:15.908877 16729
SYSP_HEARTBEAT                 2019-05-31 14:07:16.908872 16730
SYSP_HEARTBEAT                 2019-05-31 14:07:17.908866 16731
SYSP_HEARTBEAT                 2019-05-31 14:07:18.908867 16732
SYSP_HEARTBEAT                 2019-05-31 14:07:19.908867 16733
SYSP_HEARTBEAT                 2019-05-31 14:07:20.908877 16734
SYSP_HEARTBEAT                 2019-05-31 14:07:21.908875 16735
SYSP_HEARTBEAT                 2019-05-31 14:07:22.908880 16736
SYSP_HEARTBEAT                 2019-05-31 14:07:23.908879 16737
SYSP_HEARTBEAT                 2019-05-31 14:07:24.908871 16738
SYSP_HEARTBEAT                 2019-05-31 14:07:25.908867 16739
^C
-------------------------------TERMINAL CONNECTED DIRECT---------------------
SYSP_HEARTBEAT
    State:            connected
    Host:             localhost:5064
    Access:           read, write
    Element count:    1
^C
Date: Sat, Jun 1, 2019, 9:36 AM
To: Jure Varlec <[email protected]>
Cc: <[email protected]>
This sounds similar to what we are experiencing now. I'll try without the no_cache option and see what happens, Monday.
On Sat, Jun 1, 2019, 4:43 AM Jure Varlec via Tech-talk <[email protected]> wrote:
I have observed the same behaviour. In addition, I have observed that
it depends on the -no_cache option. I can't think of an a priori
reason why caching would affect monitors (apart from storing their
value, of course), but it goes beyond just the first monitor after
subscription.
With caching enabled:
  - first subscription yields just one monitor, as expected;
  - subscribing with event mask set to 'a' works as expected;
  - caput command returns the old value (which is understandable, if
    annoying).
With the -no_cache option:
  - first subscription yields two monitors;
  - subscribing with event mask set to 'a' results in no monitors when
    the record changes alarm status.
Log events behave as expected as long as the -archive option is
given. I hope these observations will help with tracking down the
issue.
Best,
Jure
On Friday, May 31, 2019 6:50:05 PM CEST William Layne via Tech-talk wrote:
> I ran two tests with two different PV types, ENUM and LONG. I saw the same
> behavior as before.
> In each test I ran cainfo followed by a camonitor in two different
> terminals, one directed at the gateway and one at the direct network.
> Cainfo for terminals directed at gateway we're using localhost:5064. The
> cainfo for terminals directed at direct network were using
> <broadcast>:<random port that ioc was using for tcp>.
> Camonitor for terminals directed at the gateway saw duplicate values in
> camonitor. The terminals directed at the direct network did not.
> On Wed, May 29, 2019, 5:59 PM William Layne <[email protected]>
> wrote:
> > I left out the other environment variables, but we have
> > EPICS_CA_AUTO_ADDR_LIST and do not see any exceptions or warnings for
> > duplicate IOCs. The logfile for the gateway does have one exception for
> > an unrelated PV (which I know is duplicated between two servers).
> > I can also confirm that I only see one update on the main network.
> > When I get in tomorrow, I will run cainfo and camonitor with main
> > network/localhost side by side.
> > On Wed, May 29, 2019, 5:51 PM Johnson, Andrew N. <[email protected]> wrote:
> >> I agree that setting EPICS_CA_AUTO_ADDR_LIST to NO may be important, but
> >> if that's the only issue it should only result in Duplicate PV warnings
> >> from camonitor, not in duplicated heartbeat monitor values on the
> >> connected
> >> channel.
> >> What hostname does the "cainfo" program tell you the PV is found on, and
> >> have you been seeing any warnings about duplicate PVs found?
> >> Is your Gateway generating any warnings about duplicate PVs? I suspect
> >> they'd go into a logfile but I forget exactly how that is configured.
> >> Can you run camonitor connected to the main network and report whether
> >> you see the same duplicate heart-beat values? Repeat that with cainfo
> >> too...
> >> - Andrew
> >> On 5/29/19 4:36 PM, Mooney, Tim M. via Tech-talk wrote:
> >> You probably want to set EPICS_CA_AUTO_ADDR_LIST to "NO".  Setting
> >> EPICS_CA_ADDR list doesn't restrict attention to the named IP addresses,
> >> it
> >> just adds them to the list of addresses already found in the init
> >> process.
> >> Tim Mooney ([email protected]) (630)252-5417
> >> Beamline Controls Group (www.aps.anl.gov)
> >> Advanced Photon Source, Argonne National Lab
> >> *From:* [email protected] <[email protected]>
> >> <[email protected]> on behalf of William Layne via Tech-talk
> >> <[email protected]> <[email protected]>
> >> *Sent:* Wednesday, May 29, 2019 4:14 PM
> >> *To:* Jemian, Pete R.
> >> *Cc:* [email protected]
> >> *Subject:* Re: Receiving duplicate monitor values using CA PV Gateway
> >> Forgot to CC tech talk. Oops.
> >> Yes, we have a few interfaces. I guess it would help to give some info on
> >> that. We have it setup with client and gateway both on the same machine:
> >> Client environment settings:
> >> EPICS_CA_ADDR_LIST=localhost; EPICS_CA_SERVER_PORT=5064;
> >> Gateway settings:
> >> -cip <network broadcast>
> >> -sip localhost
> >> IOC settings:
> >> EPICS_CA_ADDR_LIST=<network broadcast>; EPICS_CA_SERVER_PORT=5064;
> >> [Client] <--> ||localhost|| <--> [Gateway] <--> ||network broadcast||
> >> <--> [IOC]
> >> On Wed, May 29, 2019, 4:33 PM Jemian, Pete R. via Tech-talk <
> >> Does your workstation have two active network interfaces?
> >> Some modern Linux distributions install with a hypervisor that runs the
> >> Linux OS as a guest to that hypervisor.  The hypervisor has a management
> >> network interface and the linux OS has a separate one.  Each are on the
> >> same physical network connection.
> >> On 2019-05-29 3:28 PM, William Layne via Tech-talk wrote:
> >> > Hey all,
> >> > We are seeing duplicate values when first creating our subscriptions
> >> > through the CA Gateway. Is this normal? If not, does anyone know what
> >> > might be causing it?
> >> > Note: We are on EPICS V3.14.12.8 and Gateway 2.1.0
> >> > We see this in our applications and in tools such as camonitor. Here is
> >> > an example output from camonitor, for a heartbeat PV updating every
> >> second:
> >> > $ camonitor IOC1_HEARTBEAT
> >> > IOC1_HEARTBEAT               2019-05-29 20:19:51.038659 7651
> >> > IOC1_HEARTBEAT               2019-05-29 20:19:52.038654 7652
> >> > IOC1_HEARTBEAT               2019-05-29 20:19:53.038657 7653
> >> > ^C
> >> > Thanks,
> >> > William 'Casey' Layne
> >> Pete R. Jemian, Ph.D.                 <[email protected]>
> >> Beam line Controls and Data Acquisition (BC, aka BCDA)
> >> Advanced Photon Source,    Argonne National Laboratory
> >> Argonne, IL  60439                    630 - 252 - 3189
> >>        Education is the one thing for which people
> >>           are willing to pay yet not receive.
> >> Complexity comes for free, Simplicity you have to work for.
Re: Receiving duplicate monitor values using CA PV Gateway Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] Re: How to share asyn's queue thread among ports? Klemen Vodopivec via Tech-talk
Next: Re: Scanning 101 Hinko Kocevar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Receiving duplicate monitor values using CA PV Gateway William Layne via Tech-talk
Next: Re: Receiving duplicate monitor values using CA PV Gateway Johnson, Andrew N. via Tech-talk
ANJ, 03 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
