1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Unexpected change in behaviour of ai/ao device support
From: "michael.abbott--- via Tech-talk" <[email protected]>
To: "tech-talk ([email protected])" <[email protected]>
Date: Tue, 11 Jun 2019 07:57:53 +0000
At Diamond we are a bit behind the times, so I am four years late in reporting the following problem.  In upgrading our EPICS base from 3.14.12.3 (honestly!) to 3.14.12.7 (keeping things up to date; we're nearly on RHEL7), we have discovered that the ai and ao record support for our Hytec cards is now broken.
The underlying problem is that the driver support relies on being able to set the ROFF field to a negative value.  Unfortunately this is no longer possible, and the result is that ao outputs drive into maximum negative output voltage (potentially very damaging), and the ai inputs can also produce nonsense values (haven't actually tried yet, but the driver code is also now clearly broken).
In release 3.14.12.5 the following change was noted in the release note:
aoRecord raw conversion overflows
The ao record type now checks converted raw values and limits them to the 32-bit integer range before writing them to the RVAL field. Previously value overflows relied on Undefined Behaviour which could give different results on different platforms. The ROFF fields of the ao and ai record types are now DBF_ULONG to allow an ROFF setting of 0x80000000 to work properly.
The corresponding change can be seen as commit f498b36 here:
	https://github.com/epics-base/epics-base/commit/f498b36438703eb941eaac15c87f94b8d679def6
Unfortunately, changing fields from signed to unsigned has serious side effects, and I find it very hard to understand how this change happened, particularly on a minor point release like this.
Going forward, I'm not sure what the correct solution is.  This change is now clearly embedded into all subsequent versions of EPICS, so I doubt that reverting it is a serious option.  However, any documentation I have been able to find still refers to the ROFF fields as LONG.  Clearly we'll have to fix our internally supported drivers, but I do wonder who else is affected.
Why has noone else noticed this issue before now?
Re: Unexpected change in behaviour of ai/ao device support Ralph Lange via Tech-talk
Prev: Re: RELEASE file Ralph Lange via Tech-talk
Next: EPICS June 2019 Meeting talks are on-line Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: RELEASE file Mark Rivers via Tech-talk
Next: Re: Unexpected change in behaviour of ai/ao device support Ralph Lange via Tech-talk
ANJ, 29 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
