1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics performance test tools or results
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 1 Jul 2019 18:45:01 +0000
Hi Han,
On 6/30/19 12:42 PM, Jeong Han Lee via Tech-talk wrote:
Is there a standard EPICS CA/PA or V3/V4/V7 performance test scenario or tools, or even results?
There have been various performance measurements made over the years, and we even collected some results about individual VME CPU boards, but those results aren't terribly meaningful nowadays (the last result recorded was measured in 2007) and the code we used will probably need work to get it to build on recent EPICS releases. This thread has some information about that application, the measurements are in the performApp/TIMING text file.
In other form of question, "do we have the standard procedure to see deployed IOC limitation?"
No. I guess most people see whether it's fast enough for their application and restructure or adjust it until it is.
In other form of question, "do we have a benchmark tool for any IOC or application?"
Base builds a program called catime which measures the performance of a CA client/server connection (there are some instructions on how to run it in the CA reference documentation).
Other tests have been performed by various people over the years and described in tech-talk messages or talks at collaboration meetings, but we don't have a standard as such.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: epics performance test tools or results Jeong Han Lee via Tech-talk
Prev: RE: [EXTERNAL] Beckhoff BK9000 support survey Wallace, Alex via Tech-talk
Next: RE: [AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: epics performance test tools or results Jeong Han Lee via Tech-talk
Next: Re: epics performance test tools or results Jeong Han Lee via Tech-talk
ANJ, 03 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
