1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: RE: [AsynDriver] getAddress and callbacks
From: Joao Afonso via Tech-talk <[email protected]>
Date: Tue, 2 Jul 2019 07:33:47 +0000
Hi Mark,
Sorry for the late response.
Thank you for implementing those changes.
For now, I had to modify the device support module in a way that is still compatible with previous versions of asynDriver, but I may go back to use "getAddress()" in the future.
Regarding the TIME fields, I think you are right. It was caused by an unrelated bug.
Best regards,
Joao
Sent: 19 June 2019 22:04
To: Joao Afonso
Cc: [email protected]
Ø  Do you foresee adding them in a future release?
I have changed the calls from pasynManager->getAddr() to asynPortDriver::getAddress() in all of the callback routines in asynPortDriver.  This will call your overridden getAddress() method, while having no impact on existing code that does not override this method.
Ø  The only problem I noticed is that the TIME field is now always showing <undefined>. I don't know if it was triggered by this, because I didn't look that much into it.
I did not observe that, the TIME fields of records which process as a result of asynPortDriver callbacks seem fine.  Perhaps you were looking at some records that had not yet processed?
My changes are on the master branch of asyn if you want to test them.
Sent: Monday, June 17, 2019 8:52 AM
Hi Mark,
Thank you for the clarification.
I was also wondering if those changes could be done.
I tried it like you suggested and it worked mostly fine.
Anyway, I prefer not to have a dependency on a custom asynPortDriver modification, so I will try a different approach that doesn't depend on these changes.
Best regards,
Joao
Sent: 14 June 2019 19:29
To: Joao Afonso
Hi Joao,
Perhaps I spoke too soon.  It seems like it might work to replace this in asynPortDriver.
        pasynManager->getAddr(pInterrupt->pasynUser, &address);
with this
        this->getAddress(pInterrupt->pasynUser, &address);
Why don’t you try that and see if it works?  If asynPortDriver::getAddress has not been overridden then this should not affect the existing behavior.
From: [email protected] <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Friday, June 14, 2019 12:23 PM
To: 'Joao Afonso' <[email protected]>
Hi Joao,
Ø  In those cases, the IOC will get the address from "pasynManager->getAddr()", and not from getAddress(), which breaks the program.
Ø  (for ex. in paramList::octetCallback())
The callbacks are traversing a linked list of clients that have registered for callbacks.  This is typically asyn device support, but it is not limited to that.  That linked list is created outside of asynPortDriver by asynManager when each client registers for callbacks.   For example, this is the abbreviated code in devAsynInt32.c
    pasynUser = pasynManager->createAsynUser(processCallback, 0);
    pPvt->pasynUser = pasynUser;
    status = pasynEpicsUtils->parseLink(pasynUser, plink,
               &pPvt->portName, &pPvt->addr, &pPvt->userParam);
    status = pasynManager->connectDevice(pasynUser, pPvt->portName, pPvt->addr);
    status = pPvt->pint32->registerInterruptUser(
               pPvt->int32Pvt,pPvt->pasynUser,
               pPvt->interruptCallback,pPvt,&pPvt->registrarPvt);
So that pPvt->pasynUser has been connected to a particular port and address, typically specified in the OUT in INP link in the record.  The asynPortDriver callback functions are retrieving the address stored in that pasynUser in the linked list node via pasynManager->get_addr().
    pnode = (interruptNode *)ellFirst(pclientList);
    while (pnode) {
        asynInt32Interrupt *pInterrupt = (asynInt32Interrupt *) pnode->drvPvt;
        /* If this is not a multi-device then address is -1, change to 0 */
        if (address == -1) address = 0;
        if ((command == pInterrupt->pasynUser->reason) &&
            (address == addr)) {
I don’t see how it could have access to the address that your getAddress() method is generating?
Sent: Friday, June 14, 2019 11:51 AM
Subject: [AsynDriver] getAddress and callbacks
Hello Mark,
Sorry to bother you, I have a question regarding the usage of this function:
I have a use case where it is useful to override asynPortDriver::getAddress() to get a custom reason and address.
These values are chosen previously by drvUserCreate(), and stored in pasynUser->drvUser and pasynUser->reason.
This seems to work well for gets and puts, but not when a callback for for a "I/O Intr" record is executed.
Is there a way to make the callbacks also use the custom asynPortDriver::getAddress() value?
Thank you in advance,
Joao
[AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
RE: [AsynDriver] getAddress and callbacks Mark Rivers via Tech-talk
RE: [AsynDriver] getAddress and callbacks Joao Afonso via Tech-talk
Prev: Re: epics performance test tools or results Johnson, Andrew N. via Tech-talk
Next: Re: [EXTERNAL] Beckhoff BK9000 support survey Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: RE: [AsynDriver] getAddress and callbacks Mark Rivers via Tech-talk
Next: A-82x PIglide Motion Controller Sobhani, Bayan via Tech-talk
ANJ, 02 Jul 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
