Hi Kiman,
On 7/25/19 11:20 PM, Ha, Kiman via Tech-talk wrote:
That's a right solution! Thanks a lot.
There are no base-3.16.2 compile issues, but "make runtests" result shows a few errors. Do these errors affect any application?
The errors you saw in the output are actually parts of the test that are meant to fail but which output an error message while running. The most important parts of the output from 'make runtests' are the summaries of the test results that follow the "... ok"
or "... Failed" lines:
All tests successful.
Files=13, Tests=357, 7 wallclock secs ( 0.30 usr 0.05 sys + 5.85 cusr 0.51 csys = 6.71 CPU)
Result: PASS
Test Summary Report
epicsCalcTest.t (Wstat: 0 Tests: 613 Failed: 38)
Failed tests: 225, 511, 522, 578-604, 606-613
Files=41, Tests=4096, 185 wallclock secs ( 1.35 usr 0.13 sys + 2.70 cusr 0.90 csys = 5.08 CPU)
Result: FAIL
Failed 1/41 test programs. 38/4096 subtests failed.
Files=19, Tests=2822, 82 wallclock secs ( 0.97 usr 0.04 sys + 19.68 cusr 0.40 csys = 21.09 CPU)
Result: PASS
Files=1, Tests=9, 0 wallclock secs ( 0.07 usr 0.02 sys + 0.09 cusr 0.03 csys = 0.21 CPU)
Result: PASS
Files=4, Tests=1612, 3 wallclock secs ( 0.53 usr 0.01 sys + 0.14 cusr 0.04 csys = 0.72 CPU)
Result: PASS
Files=2, Tests=58, 1 wallclock secs ( 0.10 usr 0.01 sys + 0.05 cusr 0.02 csys = 0.18 CPU)
Result: PASS
Files=13, Tests=3141, 18 wallclock secs ( 0.93 usr 0.03 sys + 1.91 cusr 0.18 csys = 3.05 CPU)
Result: PASS
So in your case the only test that is actually failing is epicsCalcTest, and it would be useful for us to see the detailed output from that test. To get that, please run these commands and respond with the output from the Perl script (it will be over 600 lines
long, feel free to send it as an attached file):
cd src/libCom/test/O.linux-arm
perl epicsCalcTest.t
- Andrew
Complexity comes for free, Simplicity you have to work for.
- epics base compilation for ARM Cotex-A53 (ARM64bit) Ha, Kiman via Tech-talk
- Re: epics base compilation for ARM Cotex-A53 (ARM64bit) Michael Davidsaver via Tech-talk
- RE: epics base compilation for ARM Cotex-A53 (ARM64bit) Ha, Kiman via Tech-talk
Hardcoded scale factor on pmac George Nicolas Kontogiorgos via Tech-talk
<2019>
<2019>
ANJ, 30 Jul 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
