1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: pmac driver on Debian Stretch
From: "Davis, Mark via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 31 Jul 2019 12:38:56 +0000
Hi all (Giles in particular),
I wanted to pass on a couple of issues I ran in to while working on
getting version 2-4-10 of the Power PMAC driver working on a machine
running Debian Stretch.
The first issue I ran in to is rather trivial:
     This call in pmacCSAxis.cpp:
         sprintf(acc_buff, pC_->getCSAccTimeCmd(fabs(max_velocity /
acceleration) * 1000.0).c_str());
     and this call in interactive.cpp:
         printf(buff);
The new system have vers 6.3.0 of g++, and the list of options includes
-Werror=format-security.  This means that the use of non-constant (or
non literal?) strings for what is normally the "format" string is
treated as an error.  This is a reasonable safeguard, since if there was
an error in the generation of the "format" string that resulted in a "%"
char being in it, that could cause all kinds of trouble.
In any case, the solution is simple enough:  Simply add an actual format
string argument: "%s".  Although in the first case, it seems like it
would make sense to just replace sprintf() with a copy operation.
The next issue I found appears to be a difference in how the compiler
handles this statement in pmacCommandStore::buildCommandString():
       sprintf(commandString[qtyCmdStrings], "%s %s",
commandString[qtyCmdStrings], key.c_str());
On my older development machine running Jessie (with g++ vers 4.9.2),
this has the intended effect, which is to add the value of key.c_str()
to the end of the current contents of commandString[qtyCmdStrings].
On my newer machine running Stretch (with g++ vers 6.3.0), the result is
that current contents of commandString[qtyCmdStrings] is replaced with a
space followed by the value of key.c_str().  This call occurs in two
places:  Once before a loop (to initialize the commandString[] element),
so the result is what is wanted (even if mostly by accident in this
case).  But for the call inside the loop, the result is that the
commandString[...] value contains only a space followed by the last
value key.c_str() had (rather than the list of commands it was intended
to contain).
I was tempted to fix this by doing something like this:
     int curLen = strlen(commandString[qtyCmdStrings]);
     sprintf(commandString[qtyCmdStrings]+curLen, "%s %s",
This would PROBABLY be safe, but since I don't know exactly what the
underlying logic of sprintf() is doing now (or perhaps some new compiler
optimization?), it seemed safer to NOT use the same array in both the
target and the source arguments.  So instead I changed it to copy the
current value to a temp string each time and use that in the call:
     char curStr[1024];
     strcpy(curStr, commandString[qtyCmdStrings]);
     sprintf(commandString[qtyCmdStrings], "%s %s", curStr, key.c_str());
There are of course lots of other ways this could be fixed (and
additional safeguards added), but this is sufficient to verify what the
problem is with the existing code when using the newer compiler and
libraries.
Mark Davis
NSCL/FRIB
Control Systems Software Engineer
[email protected]
___________________________________________________________________________________________________
Re: pmac driver on Debian Stretch J. Lewis Muir via Tech-talk
Prev: Pointer corruption on Windows Koennecke Mark (PSI) via Tech-talk
Next: RE: [motorPIGCS2] can't turn on servo state of PI E-712 Allan Serra Braga Bugyi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Pointer corruption on Windows Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Re: pmac driver on Debian Stretch J. Lewis Muir via Tech-talk
ANJ, 15 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
