1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: use CA Client in Xilinx MicroBlaze system
To: [email protected]
Date: Mon, 9 Sep 2019 20:15:04 +0800 (GMT+08:00)
hi,
    i want to use a CA Client in the Xilinx MicroBlaze System(mean i want to use some API to write a CA client), i don't know if i have to build a EPICS base for that system.(Actually, i don't know if there is any way to build a EPICS base for that system).
    i read about some files in the EPICS base R3.14.12.8, Such as CONFIG_SITE:
#  The host architecture performing the build, in the form
#       <operating system>-<architecture>[-<toolset>]
#  Currently Supporting:
# aix-ppc                (IBM compiler used for host builds)
# aix-ppc-gnu            (GNU compiler used for host builds)
# cygwin-x86             (cygwin compiler used for host builds)
# cygwin-x86_64          (cygwin compiler used for host builds)
# darwin-ppc             (PowerPC based Apple running OSX)
# darwin-ppcx86          (Universal binaries for both CPUs)
# darwin-x86             (Intel based Apple running OSX)
# freebsd-x86            (GNU compiler used for host builds)
# freebsd-x86_64         (GNU compiler used for host builds)
# linux-arm              (GNU compiler used for host builds)
# linux-ppc              (GNU compiler used for host builds)
# linux-ppc64            (GNU compiler used for host builds)
# linux-x86              (GNU compiler used for host builds)
# linux-x86_64           (GNU compiler used for host builds)
# linux-x86-borland      (Borland C++ compiler used for host builds)
# solaris-sparc          (Sun compiler used for host builds)
# solaris-sparc-gnu      (GNU compiler used for host builds)
# solaris-sparc64        (Sun compiler used for host builds)
# solaris-sparc64-gnu    (GNU compiler used for host builds)
# solaris-x86            (Sun compiler used for host builds)
# solaris-x86-gnu        (GNU compiler used for host builds)
# solaris-x86_64         (Sun compiler used for host builds)
# solaris-x86_64-gnu     (GNU compiler used for host builds)
# win32-x86              (MS Visual C++ compiler used for host builds)
# win32-x86-cygwin       (WIN32 API with cygwin GNU compiler used for host builds)
# win32-x86-mingw        (MinGW compiler used for host builds)
# win32-x86-static       (MS Visual C++ compiler used for host builds)
# windows-x64            (MS Visual C++ compiler used for host builds)
# windows-x64-mingw      (MinGW compiler used for host builds)
# windows-x64-static     (MS Visual C++ compiler used for host builds)
#  Debugging builds:
# linux-arm-debug        (GNU compiler used for host builds)
# linux-x86-debug        (GNU compiler with -g option for host builds)
# linux-x86_64-debug     (GNU compiler with -g option for host builds)
# solaris-sparc-debug    (sun compiler no optimization,-g for debugging info)
# win32-x86-debug        (MS Visual C++ compiler with debug option for host builds)
# windows-x64-debug      (MS Visual C++ compiler with debug option for host builds)
#  EPICS_HOST_ARCH is a required environment variable
#  Do not set EPICS_HOST_ARCH in this file.
#  Use base/startup files to set EPICS_HOST_ARCH or
#  provide EPICS_HOST_ARCH on the GNU make command line.
#  The cross-compiler architectures to build EPICS for
#       ios-arm                 (darwin-x86 host)
#       ios-386                 (darwin-x86 host)
#       linux-386               (linux-x86 host)
#       linux-486               (linux-x86 host)
#       linux-586               (linux-x86 host)
#       linux-686               (linux-x86 host)
#       linux-arm               (linux-x86 or -x86_64 host)
#       linux-arm_eb            (linux-x86 host)
#       linux-arm_el            (linux-x86 host)
#       linux-athlon            (linux-x86 host)
#       linux-cris              (Axis GNU crosscompiler on linux-x86 host)
#       linux-cris_v10          (Axis GNU crosscompiler on linux-x86 host)
#       linux-cris_v32          (Axis GNU crosscompiler on linux-x86 host)
#       linux-microblaze
#       linux-xscale_be
#       vxWorks-486
#       vxWorks-68040
#       vxWorks-68040lc
#       vxWorks-68060
#       vxWorks-pentium
#       vxWorks-ppc32           (32-bit PowerPC CPUs with full FPU)
#       vxWorks-ppc32sf         (32-bit PowerPC CPUs without FPU)
#       vxWorks-ppc603
#       vxWorks-ppc603_long
#       vxWorks-ppc604
#       vxWorks-ppc604_long
#       vxWorks-ppc604_altivec
#       vxWorks-mpc8540
#       vxWorks-mpc8548
#       RTEMS-at91rm9200ek
#       RTEMS-beatnik
#       RTEMS-gen68360
#       RTEMS-mcp750
#       RTEMS-mvme167
#       RTEMS-mvme2100
#       RTEMS-mvme2700
#       RTEMS-mvme3100
#       RTEMS-mvme5500
#       RTEMS-pc386
#       RTEMS-psim
#       RTEMS-uC5282
#       win32-x86-mingw         (linux-x86 or -x86_64 host)
   there is a cross complier architecture, linux-microblaze. does that mean i can run epics base on MicroBlaze-based linux system? i know that Xilinx provide some documents to run a linux on microblaze.
   and when i use a CA client API(such as ca_get, ca_put) on a windows PC, it seems that i don't need to build EPICS base on the windows PC. the CA client API only needs the ca.dll and Com.dll(for windows PC). if i use libca.a and libCom.a(for linux system) in a microblaze-based linux system, can i do the same thing as i do on windows PC?
   i can't change the records in the IOCs, because it will cause many other problems (other system also use these PVs). the only thing i can do is to read or write the PVs' values.
   could you please give me some advice?
Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
Prev: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Mark Rivers via Tech-talk
Next: pyepics callback Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: pyepics autosave Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
ANJ, 09 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
