1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: pyepics callback
From: Alfio Rizzo via Tech-talk <[email protected]>
Date: Mon, 9 Sep 2019 13:24:39 +0000
Hi
I made a simple python script to get the updated value of my PV
with a simple callback function :
import epics
import time
def onChanges(**kw):
    print ('PV Changed! ', kw["pvname"], kw["value"], kw["units"], time.ctime())
mypv = epics.PV("TCU6:RF")
mypv.add_callback(onChanges)
while True:
    pass
The issue is that the unit is shown as None even if it defined in the .db
PV Changed!  TCU6:RF -39.69 None Mon Sep  9 15:03:58 2019
PV Changed!  TCU6:RF -39.73 None Mon Sep  9 15:03:59 2019
PV Changed!  TCU6:RF -39.71 None Mon Sep  9 15:04:00 2019
PV Changed!  TCU6:RF -39.7 None Mon Sep  9 15:04:01 2019
PV Changed!  TCU6:RF -39.67 None Mon Sep  9 15:04:02 2019
But if I add this line on the script before to add the callback
mypv.units
Then when I restart the script it shows the unit correctly
PV Changed!  TCU6:RF -39.79 dBm Mon Sep  9 15:04:31 2019
PV Changed!  TCU6:RF -39.71 dBm Mon Sep  9 15:04:32 2019
PV Changed!  TCU6:RF -39.69 dBm Mon Sep  9 15:04:33 2019
Is this a bug/feature or I am doing something wrong ?
Thanks
Best
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
Re: pyepics callback Eric Norum via Tech-talk
Re: pyepics callback Matt Newville via Tech-talk
Prev: use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
Next: Re: pyepics callback Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Re: use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
