1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: use CA Client in Xilinx MicroBlaze system
To: "johnson, andrew n." <[email protected]>
Cc: [email protected]
Date: Wed, 11 Sep 2019 16:49:30 +0800 (GMT+08:00)
Oh, i find a website that use a another way to use the compiler. here are some quotes:
Microblaze gnu toolchain from Xilinx is no longer available on git. Please use gnu tools from SDK installation as below:
Dave@HAL9000:~/fmcomms1/linux$ export PATH=/opt/Xilinx/SDK/2015.2/gnu/microblaze/linux_toolchain/lin64_le/bin:$PATH
Dave@HAL9000:~/fmcomms1/linux$ export ARCH=microblaze
Dave@HAL9000:~/fmcomms1/linux$ export CROSS_COMPILE=microblazeel-xilinx-linux-gnu-
so i think it needs to install the SDK, and then i can use the compiler.
use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
Re: Re: use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
Prev: Re: Re: use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
Next: RE: Driver for Smargon gniometer James.OHea--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: pyepics callback Alfio Rizzo via Tech-talk
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
