I have check with local variables works if I set manually the type of data. The think is that I would like to set a PV that I have defined in a DB. The type of data that I have is Access: read, write Native data type: DBF_DOUBLE Request type: DBR_DOUBLE If I used caput for setting the PV there is no problem. But it is impossible to set this variable through a script. I get following exception: Traceback (most recent call last): File "<script>", line 7, in <module> at org.csstudio.vtype.pv.jca.JCA_PV.performWrite(JCA_PV.java:547) at org.csstudio.vtype.pv.jca.JCA_PV.write(JCA_PV.java:412) at org.csstudio.simplepv.vtypepv.VTypePV.setValue(VTypePV.java:256) at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) java.lang.Exception: java.lang.Exception: Cannot handle type java.math.BigInteger Is there another possibility for doing that in CSS? Thank you Kay! Pilar El jue., 12 sept. 2019 a las 15:49, Kasemir, Kay (<[email protected]>) escribió: > And if I want to use a PV defined in the database? What can I use? -- Pilar Gil Jaldo
Embedded SW Engineer This
e-mail and any materials attached hereto, including, without
limitation, all content hereof and thereof are confidential and
proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*.
Without the prior written consent of Seven Solutions, this content may
not (i) be disclosed to any third party, (ii) be reproduced, modified or
otherwise used by anyone other than current employees of Seven
Solutions or its affiliates. If you are not the intended recipient or if
this message has been received in error, please immediately notify us
via e-mail and delete it. This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
ANJ, 12 Sep 2019 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
