Exactly! That works!!
Thank you very much!
Pilar
> I get following exception:
java.lang.Exception: java.lang.Exception: Cannot handle type java.math.BigInteger
Looks like Jython autoconverts the large number into a Java BigInteger, which the PV doesn't handle.
Try to pass the number as a Long or Double instead of BigInteger:
from java.lang import Long, Double
value = .. your original value ..
# Turn into Long or Double
#value = Long.valueOf(value)
value = Double.valueOf(value)
-Kay
Pilar Gil Jaldo
Embedded SW Engineer
This
e-mail and any materials attached hereto, including, without
limitation, all content hereof and thereof are confidential and
proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*.
Without the prior written consent of Seven Solutions, this content may
not (i) be disclosed to any third party, (ii) be reproduced, modified or
otherwise used by anyone other than current employees of Seven
Solutions or its affiliates. If you are not the intended recipient or if
this message has been received in error, please immediately notify us
via e-mail and delete it.
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
- CSS jython setvalue behaviour Pilar via Tech-talk
- Re: [EXTERNAL] CSS jython setvalue behaviour Kasemir, Kay via Tech-talk
- Re: [EXTERNAL] CSS jython setvalue behaviour Pilar Gil via Tech-talk
- Re: [EXTERNAL] CSS jython setvalue behaviour Pilar via Tech-talk
Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
<2019>
2025
lcaGet maximum readout array size Ha, Kiman via Tech-talk
<2019>
2025
ANJ, 13 Sep 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
