1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Sumo test
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 16 Sep 2019 09:54:45 +0200
Hi Goetz,
after a longer delay, I was looking again into the issue. I try to convert an application to sumo. I managed to create the sumo configuration for the support directory. But in the call of
sumo-scan -d . -g <support-dir> -d < base-dir> | sumo db appconvert - -C
I get an error:
Error: 'dict_keys' object is not subscriptable
So I'm stuck again. Any idea what could be the reason for that error?
Jörn
Sumo test Jörn Dreyer via Tech-talk
Re: Sumo test Jörn Dreyer via Tech-talk
Re: Sumo test Goetz Pfeiffer via Tech-talk
Prev: How to handle various response format from device in streamdevice protocol? Chiang, Liang-Chih [江良志] via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: Sumo test Goetz Pfeiffer via Tech-talk
Next: Stream Device output hex string David Vine via Tech-talk
ANJ, 16 Sep 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
