1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compile problems with R3.15.6
From: Michael Westfall via Tech-talk <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 24 Sep 2019 17:29:36 -0300
Thanks for your help, Andrew!
With what you told me, I was eventually able to figure out I needed to add the following rule to our custom set of rules:
# This is necessary in R3.15.x as a consequence of TDCT producing .db files directly
$(COMMON_DIR)/%.db$(RAW)$(DEP): $(COMMON_DIR)/%.db$(RAW)
        @$(RM) $@
        $(MSI3_15) -D $(DBFLAGS) -o $(COMMONDEP_TARGET) $< > $@
Although, I now get complaints about circular dependencies being dropped that I don't yet understand:
make[3]: Circular ../O.Common/bctest.db <- ../O.Common/bctest.db dependency dropped.
On Tue, Sep 24, 2019 at 12:26 PM Johnson, Andrew N. <[email protected]> wrote:
Hi Michael,
> On Sep 24, 2019, at 9:40 AM, Michael Westfall via Tech-talk <[email protected]> wrote:
> I have installed EPICS R3.15.6 here and now when I compile a support module, it fails with this:
> Installing created db file ../../../db/bctest.db
> /gem_sw/epics/R3.15.6/base/configure/RULES.Db:521: Building ../../../db/bctest.db (from ../O.Common/bctest.db) (../O.Common/bctest.db newer)
> + perl -CSD /gem_sw/epics/R3.15.6/base/bin/linux-x86_64/installEpics.pl -d -m 444 ../O.Common/bctest.db ../../../db
> mkdir ../../../db
> make[3]: *** No rule to make target `bctest.db.d', needed by `build'.  Stop.
> make[3]: Leaving directory `/home/mwestfall/bancomm/bancommApp/Db/O.linux-x86_64’
> I imagine this might have something to do with our custom rules that we add in here at Gemini, but I'm not seeing how.
> Any pointers as to where I should be looking to figure out why the bctest.db.d file is not being created?
The build rules changed between 3.14 and 3.15 specifically for $(DEP) = .d files; previously we would create a .d file in the same rule as the target itself and the build didn’t worry if there was no .d file. Since 3.15 we have a separate set of rules for creating .d files – look for the rules for targets %.db$(RAW)$(DEP) in Base/configure/RULES.Db and make sure you have equivalents in your ruleset.
Note that 3.15 comes with a newer version of the msi program which was required to generate .d files. In the build this is referred to with $(MSI3_15) since the older msi $(MSI) from extensions is not compatible. The associated changes may be what you’re missing.
IIRC there were quite a lot of changes to the build system between 3.14 and 3.15, I hope you have looked at those while updating your ruleset.
HTH,
- Andrew
Mike Westfall
Control Systems Software Engineer
Re: Compile problems with R3.15.6 Johnson, Andrew N. via Tech-talk
Compile problems with R3.15.6 Michael Westfall via Tech-talk
Prev: Re: Compile problems with R3.15.6 Johnson, Andrew N. via Tech-talk
Next: Re: Compile problems with R3.15.6 Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
