Hi Bruce,
I don’t think is a a problem of the env variable (it is set correctly)
And neither of the windows firewall (they are also set correctly)
I think is a problem of routing somehow
I can bind a UDP socket with nc for instance
> nc -vu 10.0.7.255 5076
Connection to 10.0.7.255 5076 port [udp/*] succeeded!
test
and listen in the wildcard port
>nc -lu -k 0.0.0.0 5076
test
Still not clear to me why the issue with epics
Best
Alfio
Hi Alfio,
Check your env variable EPICS_PVA_ADDR_LIST.
If it's set to those IP addresses and they aren't accessible from your host
it could cause those warnings.
Another possibility is that your windows firewall is blocking those network adapters
from pvget and your IOC.
Cheers,
- Bruce
Hi
I am running epics 7.0.3 release on a debian shell on windows10
When I start my ioc I get this error
Error binding socket 192.168.0.255:5076: Cannot assign requested address.
Error binding socket 224.0.0.128:5076: Cannot assign requested address.
But apparently the IOC is initialized correctly
CA and PV commands (pvget,camonitor, pvmonitor,caput,etc..) works correctly,
I got what I expect.
Only with PV commands I got again the error together with the (correct) output of the command, e.g.
>pvget gnappo:SimulationMode
gnappo:SimulationMode 2019-09-28 18:45:13.764 (1) YES
Any idea ?
Thanks
Best
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
![essLogo](png267IpaqLiE.png)
