1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: error binding socket
From: Alfio Rizzo via Tech-talk <[email protected]>
Cc: Alfio Rizzo <[email protected]>
Date: Mon, 30 Sep 2019 11:55:03 +0000
Hi Bruce,
I don’t think is a a problem of the env variable (it is set correctly)
And neither of the windows firewall (they are also set correctly)
I think is a problem of routing somehow
I can bind a UDP socket with nc for instance
> nc -vu 10.0.7.255 5076
Connection to 10.0.7.255 5076 port [udp/*] succeeded!
test
and listen in the wildcard port
>nc -lu -k 0.0.0.0 5076
 test
Still not clear to me why the issue with epics
Best
Alfio
Sent: Saturday, September 28, 2019 6:57 PM
To: '[email protected]' <[email protected]>
Subject: error binding socket
Hi Alfio,
Check your env variable EPICS_PVA_ADDR_LIST.
If it's set to those IP addresses and they aren't accessible from your host
it could cause those warnings.
Another possibility is that your windows firewall is blocking  those network adapters
from pvget and your IOC.
Cheers,
- Bruce
Hi
I am running epics 7.0.3 release on a debian shell on windows10
When I start my ioc I get this error
Error binding socket 192.168.0.255:5076: Cannot assign requested address.
Error binding socket 224.0.0.128:5076: Cannot assign requested address.
But apparently the IOC is initialized correctly
CA and PV commands (pvget,camonitor, pvmonitor,caput,etc..) works correctly,
I got what I expect.
Only with PV commands I got again the error together with the (correct) output of the command, e.g.
>pvget gnappo:SimulationMode
gnappo:SimulationMode 2019-09-28 18:45:13.764  (1) YES
Any idea ?
Thanks
Best
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
FW: error binding socket Alfio Rizzo via Tech-talk
Prev: Re: ENVVAR.right_trim in IOC console Jemian, Pete R. via Tech-talk
Next: write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: error binding socket Hill, Bruce via Tech-talk
Next: FW: error binding socket Alfio Rizzo via Tech-talk
ANJ, 01 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
