1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: record logic tips
From: "Davis, Mark via Tech-talk" <[email protected]>
Date: Mon, 21 Oct 2019 18:04:00 +0000
Hi all,
I have a new task that I figured those of you with much more experience
crafting clever record logic could help with:
The components that need to be supported:
      A record for some device to which setpoints stored in other
records are to be written (e.g. a motor record).
      A string value that provides a description of the current readback
of the device record.
      Pairs of numeric and string values.   For each pair, the number
represents one of the setpoints an operator can chose to have written to
the device record and the string represents a user-readable description
of what the associated number represents (e.g. the thickness or type of
material to place in the path of the beam, the size of a whole in a
metal plate, etc).
      The operators can change the string (and possibly the numeric)
values whenever they want.  Changes must be persistent (i.e. changes are
saved to a file and restored when the IOC restarts, probably using
autosave).
      Logic that monitors the current readback of the device record.
Whenever the position is close to (within some specified deadband) of
the numeric value in one of the numeric/string pairs, it copies the
associated string to the one that describes the current readback.  When
the readback is NOT close to one of the numeric values, it will write
something like "Invalid position" to the description string.
      And of course it has to be relatively simple for the person
configuring the IOC to change the # of numeric/string pairs supported
for a device.
No doubt I can cobble something together that will do the job, but I
figured someone out there will have already dealt with a similar need
and can provide something much simpler, more flexible, and less
cumbersome than what I am likely to create on my first attempt.
Any tips or suggestions would be much appreciated.
Mark Davis
NSCL/FRIB
Re: record logic tips Peterson, Kevin M. via Tech-talk
Re: [EXTERNAL] record logic tips Pearson, Matthew R. via Tech-talk
Prev: Re: EPICS V7 and the return of dbReadTest and dbreport Michael Davidsaver via Tech-talk
Next: RE: using epics-base with yocto Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS on your mobile with React-Automation-Studio William Duckitt via Tech-talk
Next: Re: record logic tips Peterson, Kevin M. via Tech-talk
ANJ, 21 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
