1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: record logic tips
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Davis, Mark" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 21 Oct 2019 19:23:04 +0000
Mark,
configMenu in autosave provides some of the functionality you need:
https://epics.anl.gov/bcda/synApps/autosave/autoSaveRestore_R5-6-1.html#configMenu
It doesn't, however provide this functionality:
> Logic that monitors the current readback of the device record.
> Whenever the position is close to (within some specified deadband)
> of the numeric value in one of the numeric/string pairs, it copies
> the associated string to the one that describes the current readback.
> When the readback is NOT close to one of the numeric values, it will
> write something like "Invalid position" to the description string.
If configMenu is used to put the device into a specific state, the
currName value is correct.  If the device is changed manually, the
currName value is incorrect.
Note: while it is easy to add a named config via a channel-access
client, the only way to delete a config is to delete the .cfg file.
Kevin
On 10/21/19 1:04 PM, Davis, Mark via Tech-talk wrote:
> Hi all,
> I have a new task that I figured those of you with much more
> experience crafting clever record logic could help with:
> The components that need to be supported:
> A record for some device to which setpoints stored in other records
> are to be written (e.g. a motor record).
> A string value that provides a description of the current readback of
> the device record.
> Pairs of numeric and string values.   For each pair, the number
> represents one of the setpoints an operator can chose to have written
> to the device record and the string represents a user-readable
> description of what the associated number represents (e.g. the
> thickness or type of material to place in the path of the beam, the
> size of a whole in a metal plate, etc).
> The operators can change the string (and possibly the numeric) values
> whenever they want.  Changes must be persistent (i.e. changes are
> saved to a file and restored when the IOC restarts, probably using
> autosave).
> And of course it has to be relatively simple for the person
> configuring the IOC to change the # of numeric/string pairs
> supported for a device.
> No doubt I can cobble something together that will do the job, but I
> figured someone out there will have already dealt with a similar
> need and can provide something much simpler, more flexible, and less
> cumbersome than what I am likely to create on my first attempt.
> Any tips or suggestions would be much appreciated.
> Thanks, Mark Davis NSCL/FRIB
Re: record logic tips Davis, Mark via Tech-talk
Prev: RE: using epics-base with yocto Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Next: Re: [EXTERNAL] record logic tips Pearson, Matthew R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: record logic tips Davis, Mark via Tech-talk
Next: Re: record logic tips Davis, Mark via Tech-talk
ANJ, 21 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
