1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: UDP server in model 3 motor driver
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: Lee Hudson <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Oct 2019 17:07:58 +0000
Lee,
If the default asynMotorPoller() is used, the frequency at which the
poll() methods get called can vary, since the idle poll period is not
necessarily equal to the moving poll period.  It looks like the call to
pcsControllerConfig sets both poll periods to the same value, so maybe
that hasn't been a problem.
If you create a dedicated poller thread to read the UDP stream, that
polling frequency can be independent of the pcsControllerConfig poll
periods.  This is a common approach is used areaDetector drivers.  One
example of these poller threads is pointGrey's imageGrabTask():
https://github.com/areaDetector/ADPointGrey/blob/9dda1cf68ec0757c64154144f197536d6a37622d/pointGreyApp/src/pointGrey.cpp#L880
It is likely you can make it work by reading the UDP stream in the poll
function, but I think a dedicated poller thread is a better solution.
Kevin
On 10/24/19 5:19 AM, Lee Hudson via Tech-talk wrote:
> Hi,
> I'm currently writing a motor driver and I'm not sure on the best way to
> implement a particular aspect of it. The main control link to the
> hardware is via TCP/IP, on startup the driver registers parameters of
> interest on the controller and the controller then sends all subscribed
> information out via UDP broadcasts. I think I need to create a udp
> server on the IOC, so far I am doing the following:
> *IOC boot script:*
> #TCP port for control, this works
> drvAsynIPPortConfigure("PCS1_CTRL", "192.168.113.10:51512", 100, 0, 0)
> asynOctetSetInputEos("PCS1_CTRL", 0, "\r\n")
> asynOctetSetOutputEos("PCS1_CTRL", 0, "\r\n")
> # Configure UDP port for Walter and Bai streams
> drvAsynIPServerPortConfigure(PCS1_UDP,"192.168.113.12:51513 udp", 10, 0,
> 0, 0)
> # Configure Walter and Bai PCS8000 controller
> pcsControllerConfig(PCS1, 0, 2, 20, 20)
> # Configure Walter and Bai PCS8000 Axis
> pcsAxisConfig(PCS1, 1)
> pcsAxisConfig(PCS1, 2)
> *Driver constructor(**class pcsController: public asynMotorController ):*
>      /* Connect to pcsController controller TCP for control */
>      status = pasynOctetSyncIO->connect(lowLevelPortName, 0,
> &pasynUserController_, NULL);*
>      pasynUserUDPStream = pasynManager->createAsynUser(0,0);
>      status = pasynManager->connectDevice(pasynUserUDPStream,
> streamPortName,0);
>      pasynInterface = pasynManager->findInterface(pasynUserUDPStream,
> asynOctetType, 1);*
>      pasynOctet = (asynOctet *) pasynInterface->pinterface;
>      octetPvt=pasynInterface->drvPvt;
> *Driver poll():*
> status = pasynOctet->read(octetPvt, pasynUserUDPStream, rxBuffer, 65535 - 1,
>                                &nBytesIn, &eomReason);
> In the poll() method or perhaps a separate thread elsewhere I know I
> will have to update the asyn parameters manually and call
> callParamCallbacks() to get the record to update. Am I going about this
> the right way?
> Thanks in advance
> Lee
> This e-mail and any attachments may contain confidential, copyright and
> or privileged material, and are for the use of the intended addressee
> only. If you are not the intended addressee or an authorised recipient
> of the addressee please notify us of receipt by returning the e-mail and
> do not use, copy, retain, distribute or disclose the information in or
> attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual
> and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may
> be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in
> England and Wales with its registered office at Diamond House, Harwell
> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
UDP server in model 3 motor driver Lee Hudson via Tech-talk
Prev: UDP server in model 3 motor driver Lee Hudson via Tech-talk
Next: Re: iocLogServer, logstash & procServ Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: CA exception Rolf Keitel via Tech-talk
ANJ, 24 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
