1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No TCP server started
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Sat, 2 Nov 2019 21:58:28 +0000
Hi Mark,
The Lantronix USD2100 has all sorts of settings in addition to the
serial settings; e.g. special characters
that wake up the terminal server, server settings, etc.  My startup
script has the same settings as yours
and it works when I am running from a terminal window, but not from
procServ.
## Configure IP port
drvAsynIPPortConfigure("keithley","131.225.143.116:10001",0,0,0)
Pierrick
On 11/2/19 4:52 PM, Mark Rivers wrote:
> Hi Pierrick,
>> Would you kindly share with me the settings on your terminal server?
> I not sure I know what you mean by the settings on the terminal server?
> My IOC connects to the terminal server with this command, so it is a TCP connection on port 2001.
> drvAsynIPPortConfigure("serial1", "gsets8.cars.aps.anl.gov:2001", 0, 0, 0)
> I have 26 IOCs running under procServ on the machine where I ran the test.  Quite a few of them are connected to terminal servers.
> Mark
> -----Original Message-----
> From: Pierrick M Hanlet <[email protected]>
> Sent: Saturday, November 2, 2019 4:47 PM
> Cc: Michael Davidsaver <[email protected]>; [email protected]
> Thank you Mark,
> Would you kindly share with me the settings on your terminal server? Since the IOC runs without problems from a terminal; since I have several soft IOCs running from procServ the same host computer on different ports; and since this IOC is the only one with a terminal server, I've reason to believe that the terminal server's settings may be the culprit.
> Thank you,
> Pierrick
> The terminal server that I am using
> On 11/2/19 4:23 PM, Mark Rivers wrote:
>> Hi Pierrick,
>> I just tested the following configuration:
>> Keithley 2700, RS-232
>> Digi One SP Ethernet to serial (terminal server)
>> EPICS base 7.0.3.1
>> procServ 2.7.0
>> Running an EPICS application built with the latest versions of asyn and ip (for Keithley 2700 support).
>> It works fine, I do not get the error you do.
>> I also tested with base 7.0.2 and it works as well, so I don't think your problem is the version of base.
>> I suspect something else is wrong in your application.
>> Mark
>> ________________________________
>> From: Mark Rivers
>> Sent: Thursday, October 31, 2019 9:11 PM
>> To: Pierrick M Hanlet
>> Cc: Michael Davidsaver; [email protected]
>> Hi Pierrick,
>> We routinely run linux-x86_64 IOCs that talk to Keithley 2700 multimeters using Ethernet terminal servers and running under procServ. These are running with base 7.0.2. I can test tomorrow with 7.0.3.
>> Mark
>> Sent from my iPhone
>>> On Oct 31, 2019, at 4:26 PM, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
>>> Here's what I get from a stripped down epicsEnvShow.
>>> EPICS_PATH=/home/epics/epicsDEV
>>> EPICS_IOCTOPS=/home/epics/epicsDEV/iocTops
>>> EPICS_PVA_ADDR_LIST=131.225....
>>> EPICS_BASE=/home/epics/epicsDEV/base
>>> EPICS_PVA_AUTO_ADDR_LIST=NO
>>> EPICS_EXTENSIONS=/home/epics/epicsDEV/Extensions
>>> EPICS_CA_AUTO_ADDR_LIST=NO
>>> EPICS_HOST_ARCH=linux-x86_64
>>> EPICS_CONFIG=/home/epics/epicsDEV/Config
>>> EPICS_CA_ADDR_LIST=131.225....
>>> EPICS_SOFTWARE=/home/epics/epicsDEV/Software
>>> EPICS_CA_MAX_ARRAY_BYTES=131072
>>> EPICS_SUPPORT=/home/epics/epicsDEV/Support
>>> EPICS_VERSION_MAJOR=7
>>> EPICS_VERSION_MIDDLE=0
>>> EPICS_VERSION_MINOR=3
>>> EPICS_VERSION_PATCH=0
>>> EPICS_VERSION_SNAPSHOT=
>>> EPICS_VERSION_SITE=
>>> EPICS_VERSION_SHORT=7.0.3
>>> EPICS_VERSION_FULL=7.0.3
>>> EPICS_IOC_OWNER=hanlet
>>> EPICS_IOC_GROUP=FE_group
>>> EPICS_IOC_LOCATION=???
>>>> On 10/31/19 9:19 AM, Michael Davidsaver wrote:
>>>> "CAS: No TCP server started" means that the CA server configuration,
>>>> when applied to the host system, has resulted in no TCP server
>>>> sockets being created.  So the CA server would be inoperative.  The lack of previous errors is strange.
>>>> I'd expect to see eg. some "bind error"s shown.
>>>> What $EPICS_* environment variables are set?
>>>>> On 10/29/19 10:25 AM, Pierrick M Hanlet via Tech-talk wrote:
>>>>> Hi,
>>>>> I've several soft IOCs happily running 7.0.3 on linux-x86_64 on
>>>>> different ports.  However, I have a new one which is connected to a
>>>>> ethernet<->serial converter which runs without issue from a
>>>>> terminal, but fails with "No TCP server started" when started from
>>>>> procServ.  A similar message was reported to core-talk by Heinz Junkes when using 3.16.0.1-DEV-fhi.
>>>>> This has nothing to do with my databases, as I have them commented out:
>>>>> My startup command is:
>>>>> epics:~/epicsDEV/Config/ProcLauncher> procServ -i ^D^C --killsig 15
>>>>> --logfile
>>>>> /home/epics/epicsDEV/ioc_logs/Keithley2700_2019_10_29__11_59_38.log
>>>>> --name Keithley2700 --pidfile
>>>>> /home/epics/.PROCSERV_CMD_1572368378214534208 --quiet 7718
>>>>> /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.
>>>>> cmd
>>>>> And the resulting log file has:
>>>>> @@@ Restarting child "Keithley2700"
>>>>> @@@    (as /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd)
>>>>> @@@ The PID of new child "Keithley2700" is: 7855 @@@ @@@ @@@ @@@
>>>>> #!../../bin/linux-x86_64/Keithley2700
>>>>> ## You may have to change Keithley2700 to something else ##
>>>>> everywhere it appears in this file < envPaths
>>>>> epicsEnvSet("IOC","iocKeithley2700")
>>>>> epicsEnvSet("TOP","/home/epics/epicsDEV/iocTops/Multimeter")
>>>>> epicsEnvSet("EPICS_BASE","/home/epics/epicsDEV/base")
>>>>> epicsEnvSet("EPICS_SUPPORT","/home/epics/epicsDEV/Support")
>>>>> epicsEnvSet("ASYN","/home/epics/epicsDEV/Support/asyn")
>>>>> epicsEnvSet("CALC","/home/epics/epicsDEV/Support/calc")
>>>>> epicsEnvSet("STREAM","/home/epics/epicsDEV/Support/StreamDevice")
>>>>> epicsEnvSet("ALIVE","/home/epics/epicsDEV/Support/alive")
>>>>> epicsEnvSet("KEITHLEY","/home/epics/epicsDEV/Support/Keithley")
>>>>> epicsEnvSet("EPICS_IOC_OWNER","hanlet")
>>>>> epicsEnvSet("EPICS_IOC_GROUP","FE_group")
>>>>> epicsEnvSet("EPICS_IOC_LOCATION","???")
>>>>> cd "/home/epics/epicsDEV/iocTops/Multimeter"
>>>>> ## Register all support components
>>>>> dbLoadDatabase "dbd/Keithley2700.dbd"
>>>>> Keithley2700_registerRecordDeviceDriver pdbbase ## Configure IP
>>>>> port
>>>>> drvAsynIPPortConfigure("keithley","131.225.138.251:10002",0,0,0)
>>>>> ## Debuggin
>>>>> asynSetTraceIOMask("keithley",0,2)
>>>>> asynSetTraceMask("keithley",0,9)
>>>>> ## Load record instances
>>>>> #dbLoadRecords("db/Keithley2700.db")
>>>>> #dbLoadRecords("db/alive.db")
>>>>> #dbLoadRecords("db/watcher.db")
>>>>> ## Protocol file
>>>>> epicsEnvSet("STREAM_PROTOCOL_PATH","/home/epics/epicsDEV/Support/Ke
>>>>> ithley/Keithley2700App/protocol")
>>>>> ## Start IOC
>>>>> cd "/home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700"
>>>>> iocInit
>>>>> Starting iocInit
>>>>> ## EPICS R7.0.3
>>>>> ## EPICS Base built Oct 23 2019
>>>>> Thread _main_ (0x1b50450) can't proceed, suspending.
>>>>> Dumping a stack trace of thread '_main_':
>>>>> [    0x7fc82a4fe25b]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(epicsStackTrace+0x4b)
>>>>> [    0x7fc82a4ee818]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(cantProceed+0xb8)
>>>>> [    0x7fc82a9f4be9]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(rsrv_init+0xf69)
>>>>> [    0x7fc82a9e07ab]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(dbInitServers+0x1b)
>>>>> [    0x7fc82a9f19de]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocBuild+0x2e)
>>>>> [    0x7fc82a9f1b89]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocInit+0x9)
>>>>> [    0x7fc82a4e9555]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(iocshBody+0xb15)
>>>>> [          0x407bb2]: ../../bin/linux-x86_64/Keithley2700(main+0x12)
>>>>> [    0x7fc828d64545]: /lib64/libc.so.6(__libc_start_main+0xf5)
>>>>> [          0x407bfd]: ../../bin/linux-x86_64/Keithley2700(_start+0x29)
>>>>> Any ideas?  If helpful, the device is a Lantronix UDS2100
>>>>> serial-to-ethernet converter; though I don't know if that matters.
>>>>> Thanks,
>>>>> Pierrick
>>>>> Pierrick Hanlet
>>>>> Fermi National Accelerator
>>>>> Accelerator Front End Controls
>>>>> +1-630-840-5555 -- lab
>>>>> +1-312-687-4980 -- mobile
>>>>> "Whether you think you can or think you can't, you're right" --
>>>>> Henry Ford
>>> Pierrick Hanlet
>>> "Whether you think you can or think you can't, you're right" -- Henry
>>> Ford
> Pierrick Hanlet
> "Whether you think you can or think you can't, you're right" -- Henry Ford
Pierrick Hanlet
RE: No TCP server started Mark Rivers via Tech-talk
No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Michael Davidsaver via Tech-talk
Re: No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Mark Rivers via Tech-talk
Prev: RE: No TCP server started Mark Rivers via Tech-talk
Next: RE: No TCP server started Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 02 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
